Rear lights / lamp module
Old Dec 23, 2021 | 03:53 PM
dr____g's Avatar
dr____g
6th Gear
Default Rear lights / lamp module
My rear light & brake light aren't working. The wiring underneath the rear fender looks like a bomb site - tape and crimps everywhere. I've just taken my indicators (turn lights) off the bike, so I thought I'd investigate if I could tidy up the wiring.
Looking at the wiring diagram, I expected to the following wires heading out back; Red/yellow, Blue, Black (all for the Tail Lamp), black & purple (for turn lights).
However, what I actually see are:
  1. - Orange/White
  2. - Brown
  3. - Blue
  4. - Red Yellow
  5. - Purple
  6. - Black
So, what I'd really like to do is get my rear light and brake light working again, and if possible tidy it up by removing wires only used by turn signals.
All help gratefully received, as I'm really keen to get a few miles in over the christmas holidays!
Old Dec 24, 2021 | 11:42 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
O/W is accessory power and is probably not used.
R/Y is brake light power
BE is running light power
BK is ground
V and BN is indicator but don't know which side.
Your wiring diagram is not as good as the HD one - 99949-08_en - 2008 Wiring Diagrams (harley-davidson.com)
Old Dec 24, 2021 | 02:46 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
Here is a wiring diagram for the rear lights on a2009 Sportster, sorry about the poor quality, I ttok the photo with my phones camara from the H-D workshop manual.
I hope it's of use to you.
Old Dec 24, 2021 | 03:11 PM
dr____g's Avatar
dr____g
6th Gear
thanks - what do HDI and DOM mean?
Old Dec 24, 2021 | 03:28 PM
Rob Roy's Revenge
HDI stands for Harley-Davidson International, overseas models.
DOM stands for Domestic (USA) home market models,
The main difference is in the indicator lamp units, DOM market models have running lights front in the front indicators, but not on in the rear ones.
The USA rear indicator lenses are red,
The UK has HDI models.
Hope that clears it with you.
Old Dec 24, 2021 | 03:30 PM
dr____g's Avatar
dr____g
6th Gear
Thanks for the list of what's what - that's really useful.
The diagram (reproduced below) is really interesting - the 6 cable slots on the rear light module are spot on in terms of the colours. However they are also replicated going out to the lamps - as you can see in the pic I posted. Which got me wondering - that diagram shows 3 different exit areas - one for each of the indicators and one for the rear lamp; that's clearly different to mine (again, as per pic). As this is a 2008 diagram, is there one for 2006 and 2007? I'd look myself but it looks like it needs a login of sorts....
thanks in advance - I'm really grateful for your support!
Old Dec 24, 2021 | 04:29 PM
Rob Roy's Revenge
Here is the wiring diagram for the 2006 Sportster models, sorry it isn't in colour, H-D mustn't have done the diagrams in colour in 2006.
Old Dec 25, 2021 | 02:28 AM
Andy from Sandy
A tip for the future when asking questions is to tell folk what year and model of bike you have.
2006 wiring diagrams here - 99949-06_en - 2006 Wiring Diagrams | Harley-Davidson SIP
Other stuff about your bike can be found on the hd serviceinfo portal here - https://serviceinfo.harley-davidson....cle/lookupForm
Old Dec 25, 2021 | 09:00 AM
John Harper's Avatar
John Harper
Are you sure there isn't a misprint, the Isn't the V (violet)wire for left signal and BN (brown)should be right? The colored diagram seems to have subbed V for BN on the right turn diagram.
My wiring diagram (granted it's 1991) shows brown wires to right signals, violet to left signals. Front signals are frame grounded, but use a BLK and V and BLK and BN for left and right. BLK wire is running light power. Of course, maybe the individual signals are wired the same colors from bulb to connector for universal installation, and the use of a BN wire ends at the connector block.
John
Old Dec 25, 2021 | 12:12 PM
Rob Roy's Revenge
Hello John,
There isn't a mistake i=on the coloured wiring diagram, both left and right turn signal lamp units for 2009 HDI Sportster share the same part number, 68978-00 which has black and violet wires. The socket that they plug into has the correct coloured wiring for their respective sides, black & brown for the right hand and black & violet for the left hand side.
