Lifter replacement question
Old Feb 20, 2022 | 04:20 PM
Madnss's Avatar
Madnss
Originally Posted by Thenewkid
Ok this is irritating... So I got the front lifters done and got the rear lifters in as well but when I went to put it all back together, one of the main four bolts just barely won't seat now.... It's so close, I thought it was fine but the washer still spins underneath. It doesn't look like there's anything in the bolt hole or any noticable damage to the threads.
In all honesty, I'm not sure it was ever seated completely before this job either... Does anyone have any suggestions?
the threads in the head might be gummed up. Are you using a tq wrench? Does it get tight half way down or at the very end? Did you rotate the rear wheel for front and rear cover install so the lifters are off the cam lobe?
Old Feb 20, 2022 | 04:33 PM
Thenewkid's Avatar
Thenewkid
6th Gear
Torque wrench yes but, the bolt stop turning before the specified torque rating. It doesn't get tight till right at the very end. I didn't realize it wasn't torqued till I looked really close... There's maybe 0.1 in play and yes, I rotated the read tire for both cylinders.
I'm debating taking all the bolts back out to inspect it but not sure how that'll effect the gasket. Thanks for your help.
I
Old Feb 20, 2022 | 06:19 PM
Iron Horse 13's Avatar
Iron Horse 13
Go watch a hammer video about how to reinstall head bolts.i highly recommend it.
Old Feb 20, 2022 | 09:32 PM
Thenewkid's Avatar
Thenewkid
6th Gear
S#!t man, can't I just run a shorter bolt and call it a day?? Ughhhh the reason I did this was Was it was going to be relatively straight forward and cheap. Now If I pull the head bolts out you better believe I'm gonna pull the heads and service then too... Please, can you elaborate a little about the benefits vs the time and $ involved?
Old Feb 20, 2022 | 10:24 PM
Madnss's Avatar
Madnss
I
pull it apart, gaskets will be fine. It may seem like a lot of work, but it’s worth it imho.
Old Feb 20, 2022 | 10:30 PM
Madnss's Avatar
Madnss
the 4 main rocker bolts are different lengths! Do you have one of them in the wrong side?!
Old Feb 20, 2022 | 10:45 PM
Thenewkid's Avatar
Thenewkid
6th Gear
huh they didn't seem different but then I never compared them to each other either. It couldn't have been that much difference in them besides a few threads... Yeah I could easily have one in the wrong side which would mean there is another also. But it looked like the other three seated fine and that would lead me to believe they are all the same ...
Old Feb 20, 2022 | 10:47 PM
Thenewkid's Avatar
Thenewkid
6th Gear
Nah it's not hard, and I've learned the hard way already... Much easier to tear it apart now instead of replacing pushrods valves and whatever else comes loose later
Old Mar 9, 2024 | 07:43 PM
Richard Q's Avatar
Richard Q
Stage I
Default Pushrod tube removal with heads still on?
Originally Posted by John Harper
Yes, 1991-2003, you can pull the tubes with heads on.. Just make sure to reinstall the bases carefully. I lubed the outside with oil to make sliding the seals down easier, and had no leaks. There's some tiny locator pins for the bases, make sure you're on those before tightening the base bolt. Good luck!
John
YOu're saying its possible to slide the tube base & the tube out at the bottom?
Old Mar 9, 2024 | 10:16 PM
OCSpringer's Avatar
OCSpringer
Yes, that is what he is saying. And he is correct.
johnod
EVO
32
Jan 4, 2016 02:20 PM
Mozvader
2014-2024 Touring Models
Jun 3, 2014 08:22 PM
lpd1snipe
May 7, 2014 12:33 PM
96roadking
EVO
Apr 22, 2010 03:15 PM
mac5793
Oct 31, 2006 03:23 PM
