carb leaks
Old Jun 10, 2022 | 05:24 PM
javiedames's Avatar
javiedames
5th Gear
Default carb leaks
02 XLH 883 stock 21,000 miles carb is leaking from the over flow tube on carb I recently replaced the petcock, no vacuum plugged that a long time ago,however when I turn on fuel from petcock it starts leaking does not leak while driving?
Is this a vacuum leak issue or float issue?? Thanks in advance
Old Jun 10, 2022 | 07:16 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Did you replace the vacuum petcock with another vacuum petcock or a Pingle type with no vacuum port? Might wanna clean the carb and adjust the float height.
Old Jun 10, 2022 | 07:42 PM
Y2K's Avatar
Y2K
Sounds like float is sticking.
Old Jun 10, 2022 | 07:57 PM
RANGER73's Avatar
RANGER73
Where's it leaking from? Might be a cracked fuel line.
Old Jun 11, 2022 | 10:32 AM
Gary1's Avatar
Gary1
Stuck float. .
Old Jun 11, 2022 | 10:57 AM
Midpegs's Avatar
Midpegs
Float needle probably has a particle of dirt lodged behind it .Invert the carb and blast it out with a carb cleaner spray .
Old Jun 11, 2022 | 05:01 PM
Madison Bill's Avatar
Madison Bill
Carb rebuild kit very easy. I had a 2000 - 1200 that did that.
Old Jun 11, 2022 | 05:04 PM
Jackie Paper's Avatar
Jackie Paper
Float.
It's able to keep up running. However, not a good idea however. Nor is removing the vacuum petcock.
Now you know why you should always turn off fuel. And Harley even says to do vacuum one . Harley's old single diaphragm one can go bad.
For those who do keep it. Pull a vacuum ever oil change on it. It needs rebuilt if it leaks. It can pull fuel into manifold leaking.
Newer ones have a double diaphragm. They don't leak.
Old Jun 12, 2022 | 12:58 PM
javiedames's Avatar
javiedames
5th Gear
Hey thanks for the info,
I did change out the VOES petcock for a standard, it works great however upon taking the carb apart the float was stuck makin the gas hit the overflow
Old Jun 12, 2022 | 01:06 PM
Gary1's Avatar
Gary1
I bought a petcock non vacuum for my 1998 and haven't had no issues. I never turn my fuel off when parked.
