Battery not charging
Old Jun 12, 2022 | 09:13 PM
hammer6315's Avatar
hammer6315
Originally Posted by Gary1
Yeah, take the battery out and have it load tested at Auto Zone and they sell batteries also.
There is a method for load testing the battery without removing it.
Old Jun 13, 2022 | 01:03 PM
Ricky L's Avatar
Ricky L
Stage III
Originally Posted by Andy from Sandy
Stating the obvious but if you have the knowledge on how to check the stator why didn't you carry on and check the regulator? Once you are into just changing stuff you are guessing and not trouble-shooting - a sellers best friend.
yes, I did test the original regulator and the numbers were bad. Changed out regulator and it worked for a little while and happened again. Returned the regulator, installed old one and was good for a while and back to not charging. Something I noticed the other day was the regulator being warm. Not sure if that is normal.
Old Jun 13, 2022 | 02:55 PM
Rounders's Avatar
Rounders
I was told old Harleys need the volt reg to have good ground though body to frame. Not sure if true, just what heard.
Old Jun 13, 2022 | 03:40 PM
Ricky L's Avatar
Ricky L
Stage III
Originally Posted by Rounders
Is the battery going up to around 14.4 dc when revved? Don't know XLs but is it going to around 100 bolts ac when reved?
It did at first but now that the lights are on, it shows it being a bad regulator. It did the same thing when I replaced the regulator. Worked and tested good but than it stopped charging my battery again.
Old Jun 13, 2022 | 04:38 PM
Rounders's Avatar
Rounders
The old one did not magically start working again. Something else is funny. Bad connection. I don't know.
What brand of parts?
steelbuddha
Sep 13, 2017 08:40 AM
WOLFE1584
Mar 11, 2013 05:57 PM
darrinfish
Aug 22, 2010 07:27 AM
dogit56@aol.com
Nov 27, 2009 12:13 AM
helstone
Sep 4, 2007 04:55 AM
