07 Sporty Wont maintain steady throttle jerky
Old Aug 9, 2022 | 04:49 PM
HDRIDER7's Avatar
HDRIDER7
I sprayed around the intake with WD-40 dry lube because i couldnt find carb clean and it seemed like the idle went up when i did but im not sure. Also exhaust ports felt like there was no air coming out. Checked the air filter and it was a little dirty. Wonder if it has ever been changed. Looks like the stock one. Bike has 5500 miles on it.
Old Sep 16, 2022 | 04:48 PM
HDRIDER7's Avatar
HDRIDER7
I ended up changing the champion plugs that where in there with NGK iridiums and it seemed to make a world of s difference, no more bucking and popping. All i have to do now is change the air filter out because it is somewhat dirty and it is the OEM filter. However the champions that i took out where very white on the porcelain, which seems to me a lean condition. I check 02 sensor voltage readings thru FP3 and they where all in spec. Mind boggled
B88
Oct 7, 2024 06:38 PM
TexasMotorcycleRider
Milwaukee Eight (M8)
77
Jul 21, 2021 10:40 AM
Don Gratz
Jan 14, 2021 01:28 AM
north texas harley
Jun 15, 2012 10:24 AM
JollyRogers
Oct 17, 2010 10:02 PM
