Covering the basics
Old Aug 7, 2022 | 08:40 AM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
Originally Posted by onionz
What's lugging the bike mean?
It could be to do with the fact that your Iron has a 1200cc big bore kit and the stock 883 gearing, the 883 and 1200 have different gear ratios as below.
883 gear ratios. 2011 - up.
1st 10.41.
2nd 7.44.
3rd 5.35.
4th 4.58.
5th 3.93
1200 gear ratios. 2006 - up.
1st 9.32.
2nd 6.65.
3rd 4.95.
4th 4.10.
5th 3.52.
Both 883 and 1200 Sportsters from 2011 - and later use the same final drive gearing, 29T engine pulley and 68T wheel pulley. The overall final drive gear ratio is 2.35.
Old Aug 7, 2022 | 11:38 AM
onionz's Avatar
onionz
Originally Posted by Racepres
I get what others have posted... But, I do Not know what speeds we are talking???
Clutch Modulation may be your Salvation..
Do you mean Clutch Control?
Old Aug 7, 2022 | 11:43 AM
onionz's Avatar
onionz
1st 10.41.
2nd 7.44.
3rd 5.35.
4th 4.58.
5th 3.93
1st 9.32.
2nd 6.65.
3rd 4.95.
4th 4.10.
5th 3.52.
How can I confirm the bike is actually 1200cc?
Old Aug 7, 2022 | 12:07 PM
John Harper's Avatar
John Harper
Did the seller provide any receipts for the work?
Or, there is a way to measure the bore with straw to determine 883 or 1200cc.
Check Your Cylinder Size With a Straw
883 or 1200? - Check like this: 5)
  • Put in 5th gear
  • Lift rear wheel
  • Remove spark plugs
  • Place a long plastic straw, chopstick, etc. in the spark plug hole
  • Rotate tire to move cylinder to bottom dead center - lowest straw position
  • Check cylinder diagonal dimension from far bottom of cylinder to top lip of spark plug hole
  • 883 bore = 5.5“ Diagonally —- (Actual Bore Dia. is 3.000)
  • 1200 bore = 5.875” Diagonally - (Actual Bore Dia. is 3.498)
The plastic straw is unable to damage the cylinder and unlikely to fall into the cavity…
John
Old Aug 7, 2022 | 12:12 PM
John Harper
Yes, it's a balance between engaging the clutch and engine RPM. You are using the friction zone to apply controlled power. Go to a flat and level parking lot and try engaging the clutch slowly at idle. With a 1200 motor, you can actually engage the clutch and move ahead without even using the throttle, once you get comfortable with using the "friction zone." I barely need to give my 1250 throttle to get rolling.
John
Old Aug 7, 2022 | 07:24 PM
inspecto's Avatar
inspecto
I agree with what all the others have said and you need to ride, ride and ride some more. Also don't be afraid of empty parking lots.
Trusten
Nov 10, 2013 01:44 PM
swilsondds
Aug 7, 2013 05:08 AM
Antmf
Jun 7, 2013 09:21 PM
grimreaper169
Sep 19, 2009 09:07 AM
rockDAWG
May 29, 2009 03:16 PM
