Tappet cover
Old Oct 28, 2022 | 03:27 AM
SouthOfTheThames's Avatar
SouthOfTheThames
6th Gear
Default Tappet cover
Hi all, hope this seasons riding has been good for you. Thought I'd do a barrel check on my 883 over winter, seeing as I have a compression issue. Also looking at tappets (lifters in US parlance). Has anyone got a quick way of getting these things out?
I've loosened it and it swivels slightly and feels as it's held with 'O' rings. Short of grabbing the thing with Mole-grips and pulling vertically, while twisting, I'm not sure. Tried sliding a blade under while twisting, but nothing is giving way...I have a binding tappet on the front cylinder inlet, so need to check condition of suspect tappet. Any pointers will be much appreciated. Thanks.
Old Oct 28, 2022 | 07:34 AM
eighteight's Avatar
eighteight
[QUOTE=SouthOfTheThames;20900045]Hi all, hope this seasons riding has been good for you. Thought I'd do a barrel check on my 883 over winter, seeing as I have a compression issue. Also looking at tappets (lifters in US parlance). Has anyone got a quick way of getting these things out?
I've loosened it and it swivels slightly and feels as it's held with 'O' rings. Short of grabbing the thing with Mole-grips and pulling vertically, while twisting, I'm not sure./QUOTE]
You are correct on the o-rings
The bolt you`ve already removed is the only fastener
I`d pad my pliers and give it a go.
Old Oct 28, 2022 | 08:01 AM
SouthOfTheThames
6th Gear
Thanks eighteight,
Will give that a go...
Old Oct 29, 2022 | 09:59 AM
SouthOfTheThames
6th Gear
Hello eighteight,
Yes....grabbed it with pipe grips with suitable rag and levered up with stout screwdriver - sorted, cheers.
rebbe18
Apr 24, 2024 11:52 PM
BriGlide
Milwaukee Eight (M8)
Sep 30, 2021 05:52 AM
NitehawkCE
Jul 2, 2021 06:52 AM
clackavosticus
Apr 27, 2021 07:42 PM
stxscott
General Topics/Tech Tips
Sep 3, 2019 08:56 AM
