Progressive shocks installed but...
Old Aug 20, 2007 | 11:57 PM
Mark g's Avatar
Mark g
Default RE: Progressive shocks installed but...
personally, I wanted the bars to be solid as I lifted the bike incase I needed to grab it. once it was up and I stabilized the bike,then I removed everything.
Worked out well.
As long as you use the right socket,you shouldn't scratch anything.
Old Aug 21, 2007 | 07:49 PM
jmarkle's Avatar
jmarkle
There is a device that looks like a very short socket (that is what it really is) that is available on eBay or locally if you bother to check around. I used it for my fork spring replacement. No damage at all. It also made it easy to replace the caps which has to compress the spring a little before the threads catch. I don't remember how much is was but it was not expensive and worth every penny.
Old Aug 22, 2007 | 12:20 AM
Hamperdiver's Avatar
Hamperdiver
That device sounds like it would be helpful. Is it 6 pt or 12 pt and what is it called so I could search for it?
hexnut
Apr 2, 2020 06:04 PM
BlueNoser
May 2, 2011 07:39 PM
AlgorNick
Feb 25, 2011 04:30 PM
rounder
May 9, 2010 07:11 PM
xlc06
Nov 17, 2006 02:11 PM
