These 2" riser extensions utilise the stock riser, they come in black or chrome finish with extra long bolts. They are available on Fleabay for around $30 for the kit.
I want to use the stock riser but would like it to be 2" higher. I thank all who have replied.
Any chance you could post a link to those on ebay RRR, I looked and there are hundreds.
Thanks for your reply, the eBay item number for those 2" high riser extensions is 304785296366, you have to let the seller know which colour you require when you place the order.
Those riser extensions would look like pooh because it would leave a large gap between the OEM riser and the top clamp. Buy a set of the OEM Custom
style risers off eBay and cut the bottom 2" and add it under yours.
