2002 Sportster rear back tire
Old Mar 27, 2023 | 10:39 PM
Skeeter4206's Avatar
Skeeter4206
Default 2002 Sportster rear back tire
I have a question about rear tires and sizes for rims. I have a 2002 sportster 883C that had the original rear rim, which was the cast style rim. It had a 180/60R16 80H tire on that rim that was there since I acquired the bike. I wanted to get away from the cast rear rim and go with a spoked rear rim as the front was already. By the manual the rear cast rim was 16" x 3" rim, so thats what I ordered online a spoked 16" x 3" rim. Once I got the rim I went to Harley dealership to get a tire for the new rim. I asked for the wider 180/60R16 80H size tire and was told it wouldn't fit that rim. So I ended up with the 130/90 B16 tire which is what the manual says is the stock tire size.
My question would be is that rim too small to have the 180/60R16 size tire on it. This is not taking into account for sprockets offset. Thats a whole different topic. If the 16" x 3" spoked rim is too small for the wider tire, then what would be my option to get back to the wider back tire which I liked.
Old Mar 28, 2023 | 05:32 AM
eighteight's Avatar
eighteight
Check the recommended rim width for the tire you wish to purchase.
Order a wider rim and relace to your existing hub
Of course you "had" a 180 on a 3" rim
Dealer won`t do it for "liability" issues
Old Mar 28, 2023 | 10:45 AM
Madnss's Avatar
Madnss
A 180 is not going on a factory rim. 180 is not going on unless you have a widened swing arm and rear struts. Need pics
Old Mar 29, 2023 | 08:15 PM
Skeeter4206
These were rough dimensions I took on the swingarm and the widths of the tires
Old Mar 30, 2023 | 03:32 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
My 2017 has a 6" width tyre or rather 150/70 R 17 on a 4 1/2" rim.
Old Mar 30, 2023 | 10:52 AM
OCSpringer's Avatar
OCSpringer
No way a 180 rear tire is going on a 2002 sportster without serious modification although they have kits to do it.
Old Mar 30, 2023 | 11:47 AM
Madnss's Avatar
Madnss
looks like you have the swingarm width covered! A pic of the bike next!
Old Mar 30, 2023 | 12:42 PM
OCSpringer's Avatar
OCSpringer
These dimensions don't look right at all. That has to be an aftermarket kit. My stock swingarm is several inches narrower. A stock tire on a wide swingarm is going to look mighty strange. I am guessing the fender is not stock either. A 150 tire barely fits a 2002 sportster with mods, so there must be some significant changes to get a 180 on there. Look up the sportster wide tire kits and see what rims they use.
Old Mar 30, 2023 | 12:59 PM
Garry Sr's Avatar
Garry Sr
I just put a 70 series on the back of mine, it came with a 150/60 r 17. While everyone else is thinking wider I'm thinking taller for the gearing.
Old Mar 30, 2023 | 01:13 PM
Bubba Zanetti's Avatar
Bubba Zanetti
I have a friend who wedged a 150 on the back of his Sporty and it took some modding to make it work. From what I remember after seeing it is there's no way a 180 would fit a stock swingarm and fender.
