Exaust Problem
Old Aug 23, 2007 | 08:05 PM
harlanrider's Avatar
harlanrider
Default Exaust Problem
Went to dealer tonight and was going to order the Vance and Hines longshot exhaust. I have an 07 Low and they told me that they are having problems putting on the 07s because of the fuel injection. Has anyone else run in to this problem?
Old Aug 23, 2007 | 08:11 PM
commander112's Avatar
commander112
Default RE: Exaust Problem
Does V&H list the pipes as available for the XL? If so, it has holes for the O2 sensors and will work. If they do not specifically list the '07then you need to look elsewhere at this time.Go to the V&H website.
Mark
Old Aug 23, 2007 | 09:02 PM
user 6397220's Avatar
user 6397220
I have an 2007 nightser with a black ceramic D & D 2 into 1 with a powercomander 3.
had it dyno. 84.1 hp. runs great.I will have a pic up tomorrow.
Old Aug 23, 2007 | 09:57 PM
racinjason's Avatar
racinjason
You can run V&H. Get power commander part number 817-511. If the problem is O2 sensors, the power commander does away with the sensors with there O2 eliminators.Install map M817-002.
Old Aug 24, 2007 | 06:59 AM
racinjason's Avatar
racinjason
Did a little more research, actually the map download you would need for the V&H is M817-008. That's for the V&H and high flow air breather kit.
Old Aug 24, 2007 | 07:37 AM
cHarley's Avatar
cHarley
I happened to be at my indy shop the other day and there was a salesrep there selling a kit to them that allows them to easily installa bung on standard pipes to accomodate the o2 sensor.
gant
Aug 16, 2012 11:35 AM
Skyking75
Mar 15, 2010 08:02 PM
Mordrapheus
Sep 21, 2008 06:12 PM
willieb76
Exhaust System Topics
May 7, 2008 07:46 AM
TundraHawg
Sep 29, 2007 12:03 PM
