QUICK help needed
Old Aug 24, 2007 | 05:59 PM
MJStephens's Avatar
MJStephens
Default QUICK help needed
Long story short....my Nightster got bumped off phase 1 so I found a killer deal on 2007. Im picking it up tomorrow. I have V&H short shots waiting to go on it. The bike is stock right now....do I NEED to tweak the stock map if I'm only running the new pipes? Im ordering the Power Commander and a new air filter this week...I just happened on this bike so I don't have all of it yet but I still want to throw my pipes on. The bike is already broken in and just had the 1k service done.
Thanks.
Old Aug 24, 2007 | 06:37 PM
jeramy's Avatar
jeramy
Default RE: QUICK help needed
you should be able to run the slipons without needing to tweek the map.but make sure you do when you install the air cleaner
Old Aug 24, 2007 | 06:43 PM
MJStephens's Avatar
MJStephens
ORIGINAL: jeramy
These are actually full pipes. But leaving the stock A/C on, I'm hoping they aren't going to flow enough to lean the engine out.
Old Aug 24, 2007 | 06:57 PM
Thumper26's Avatar
Thumper26
Full V&H Short Shots pipes on a 2007 could be a problem because of the EFI. The injection system's oxygen sensor is in the exhaust pipe not too far from the cylinder (front, I believe)...
Old Aug 24, 2007 | 07:23 PM
MacAttack's Avatar
MacAttack
There are two O2 sensors, one on each header pipe.
Old Aug 25, 2007 | 04:24 AM
Thumper26's Avatar
Thumper26
I stand corrected!
Personally, I'm not a fan of liquid-cooled enginesor EFI.
s0j0roman
Exhaust System Topics
Oct 2, 2011 06:27 PM
jamiesonmundy
Aug 24, 2010 08:51 PM
pajerc
May 27, 2010 07:57 PM
moresky
Jul 14, 2008 01:14 PM
tplyons
Aug 7, 2007 10:21 PM
