Battery recommendations?
Old Aug 20, 2023 | 05:58 PM
Packgrog's Avatar
Packgrog
Default Battery recommendations?
After replacement stator and regulator on my 2003 Sportster, my battery has now also died. What would people recommend?
Old Aug 20, 2023 | 07:51 PM
OCSpringer's Avatar
OCSpringer
I am a fan of the oem battery from Harley for my 2003 as it is designed to be visible so I don't need to run a cover. I have gotten better life out of them as well so it's a win, win.
Old Aug 20, 2023 | 08:40 PM
CoolBreeze3646's Avatar
CoolBreeze3646
I have been using Big Crank Batteries since 2007 and have never had an issue with them, they are made in the same place as OEM H-D Batteries.
Others will have different opinions and present them, take it for what free advice is worth.
Have one in my 2003 Sportster for 3 years now and still going strong, I keep it on a tender when not in use.
You will have to decide what brand you want.
https://www.batterymart.com/p-Big-Cr...L-Battery.html
Old Aug 20, 2023 | 09:07 PM
Rounders's Avatar
Rounders
I have had great luck with factory batteries. People will say so and so makes harley batteries, changed over the years. Though the specs may not be the same.
That said all my other vehicles I run fleet farm batteries with great luck. So I am probably just paranoid.
Old Aug 20, 2023 | 09:27 PM
lightweight bob's Avatar
lightweight bob
Default Speedcell Lithium Batteries
The best you can buy hands down - normal life expectancy is 7+ years. Be sure to only use a good lithum battery charger.
Weighs less than 3 pounds. Btw - the smaller size 5.0 is fine for most bikes but baggers should use the larger 7.5 size.
Battery - https://shopspeedcell.com/collections/batteries
Charger -
Amazon Amazon
Multi-time Baja racing winner.
Old Aug 21, 2023 | 03:25 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
NEVER use a battery tender
Not sure they fully understand what is available. Also they don't know the market place with bikes that have always on electronics for security devices, etc. suggesting the battery is disconnected if you don't intend to ride in the next 7 days or longer.
Old Aug 21, 2023 | 09:07 AM
Packgrog's Avatar
Packgrog
Yeah, so here's some fun wrinkles, which makes Andy's comments appropriate:
I do not have a garage, so battery tender isn't really an option. At most I'm able to ride once per week, lately only once per month with my schedule and this godawful heat, so I do make sure that things like my phone charger are unplugged when I'm done riding for the day.
During my last real ride, I had my phone connected to the QuadLock magnetic charger through a BatteryTender USB connection. On previous rides before my regulator got replaced, the charger kept cutting out. It didn't cut out that last time, which seemed great, but after a good 2+ hour ride, it seems like the bike battery didn't get enough juice to charge it as well as my phone battery, and the bike battery died. I bought a jump pack and was able to get it running again enough to get home, riding around for a few minutes to try to charge the bike battery. Then it had to sit for another 2 weeks. Battery fully dead. Fun.
As much as I like the idea of a Lithium Ion battery, I'm on a 20-year-old Sporty. Whatever special charging parts might be needed are not on this bike. So that seems unlikely to be a great option, unless there's just some other component I would need that I don't yet know about.
I did see at least one YouTube vlogger giving a strong recommendation for Yuasa batteries. Nice as it would be to get something manufactured here in PA, they do seem pretty expensive. Don't know whether there's measurable benefit over something like an HD branded battery.
So yeah, thoughts are welcome.
Old Aug 21, 2023 | 10:29 AM
John Harper's Avatar
John Harper
"As much as I like the idea of a Lithium Ion battery, I'm on a 20-year-old Sporty. Whatever special charging parts might be needed are not on this bike. So that seems unlikely to be a great option, unless there's just some other component I would need that I don't yet know about."
I have a 1991 Sportster (33 years old next month!) and have used Shorai Lithium batteries for almost 8 years now. No special charging system needed on the bike. I do use the Shorai BMS unit after a ride, then disconnect it. My bike has no parasitic load when shut off. Taking 10 pounds of weight off my battery tray was worth the price, as repairing my oil tank and mount would be an expensive hassle. You can buy LiFEPO4 batteries with integrated BMS (EarthX).
I like the Shorai as they come in several form factors, so it fits my battery tray without spacers.
This is the one I use:
https://shoraipower.com/battery?type...03&year=381504
Here's Shorai and EarthX websites:
https://shoraipower.com/batteries-c41
https://earthxbatteries.com/about-us...thium-battery/
John
Old Aug 21, 2023 | 10:51 AM
08xl1200r's Avatar
08xl1200r
I've had good results for many years using Yuasa batteries in my other bikes but one didn't work well at all on my rubber mount Sportster, the terminal connections would loosen up a few times each year (maybe due to vibration plus the lead terminal thinning under pressure) and this would sometimes cause arcing and terminal damage. I went back to a HD battery with threaded steel inserts in the terminals and no problems since then...
Old Aug 21, 2023 | 11:18 AM
T^2's Avatar
T^2
East Penn (DEKA) batteries...
https://dekacatalog.com/
AFAIK, they are still the maker of HD's OEM battery. Also, AFAIK, they are the maker of various aftermarket brands line Big Crank etc.
You should be able to find them readily available online via a Google search.
I would save yourself a significant chunk of change and skip the Lithium batteries.
