Head Lamp Replacement
Old Feb 19, 2024 | 09:21 AM
chrisgribbin24@ymail.com's Avatar
Stage IV
Default Head Lamp Replacement
Hi I have replaced the headlamp on my 09 sportster 883 but there is 4 wires coming from the bike and 3 from the lamp see photo. I have a spare wire and I think I have the low beam ok
Any help appreciated
Thanks
Chris
Old Feb 19, 2024 | 09:49 AM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
Black = Earth or Ground.
White = High Beam.
Yellow = Dipped or Low Beam.
Orange / White = Parking or Position Lamp. (On H-D International models only).
Has your headlight got provision for the parking light, if it is an H-D domestic market unit it won't, they have position lights in the turn signals, International models have one in the headlight unit as European law calls for a parking light.
See the diagram below.
Old Feb 19, 2024 | 09:58 AM
Stage IV
hi thanks for your reply. yes my position lamp is in the head light unit
Old Feb 19, 2024 | 10:57 AM
Stage IV
Hi Thanks for your reply. yes the position/parking light is in the head light unit and It seems the green and blue wires are the problem but I have tried all the combinations I can think of
Old Feb 19, 2024 | 11:26 AM
John Harper's Avatar
John Harper
Why don't you ground the black wire, and run 12v to each of the other wires and see what lights up? You have black, green, blue, and white from the headlight assembly? Have you contacted the vendor and asked them what each wire does? It looks like you bought an aftermarket headlamp assembly, who knows what wires do what.
John
Old Feb 19, 2024 | 11:46 AM
Rob Roy's Revenge
If you have green and blue wires, they are the wrong colours, it sounds like you have either a non H-D aftermarket headlight unit or just the bulb holder is wrong. Is the headlight the stock H-D size of 5-3/4" or is it a 7" unit?
Green and blue sound like the colours on a universal bulb holder as below, if you don't have a parking light bulb holder, you will need to buy one.
You'd be best sticking to the stock H-D colours if possible incase you sell the bike at a later date, it will prevent the new owner from getting confused about the odd coloured wiring.
Old Feb 19, 2024 | 12:27 PM
John Harper
That connector might already be inside his headlamp nacelle, along with the position bulb and holder. That would make the white wire for his position light in that case.
John
Old Feb 19, 2024 | 12:47 PM
RANGER73's Avatar
RANGER73
The orange positioning wire is always on when the ignition is on.
Where as the white and yellow are controlled by the High/Low switch
and neither one is on at the same time.
Old Feb 20, 2024 | 11:47 AM
Stage IV
Ok Thanks all, I will try some of these suggestions and contact the vendor.
very much appreciated
Covenant
Electrical/Lighting/Alarm
Feb 17, 2020 08:04 PM
jester3k
Apr 5, 2017 12:35 AM
Harleyonthebrain
EVO
Jun 20, 2010 08:17 PM
mca1989
Jun 11, 2010 04:05 PM
07fsxt
Apr 12, 2009 12:16 PM
