Kick stand washer
Old Jun 17, 2024 | 10:51 AM
EasyTargetRN's Avatar
EasyTargetRN
Default Kick stand washer
I've noticed my XL1200C leans a bit farther than I'm used to and the stand slides after it makes contact. I crawled under and found that the "top hat" washers are missing that hold the pin secure. I searched the forums but didn't see anything addressing this. I haven't found an aftermarket but I'm sure there's a generic solution at the hardware store if I knew the I/O diameter..
Is there a part# for these or should I just call the dealer?
Old Jun 17, 2024 | 11:35 AM
John Harper's Avatar
John Harper
Someone posted up a long time ago about finding a suitable replacement for those bushings, but it's been a long time ago.
HD P/N: 53176-08 $6.99 each on Ronnie's HD microfiche.
Here's some Drag Specialties replacements:
https://www.ebay.com/itm/11619915602...Bk9SR7i44vCEZA
John
Old Jun 17, 2024 | 11:37 AM
perki48's Avatar
perki48
https://tcbros.com/products/jiffy-ki...WgGRaJboO7Fx_g
Old Jun 17, 2024 | 11:38 AM
EasyTargetRN
Thanks! Didn't think about Drag Specialties.
Old Jun 17, 2024 | 11:39 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I have the same bushings on my bike and what it takes is to follow the FSM or more frequently to keep them clean and greased.
The clevis pin on my bike has not a drop of rust either.
Without the top one it is hard to see how the clevis even stayed in place.
Old Jun 17, 2024 | 11:53 AM
EasyTargetRN
Thanks, another good resource
John Harper
My 1991 does not use those bushings, and it looks like they started using them in 1998. Not sure if there is a retrofit for my bike, but I have had no issues with my kickstand clevis pin, although I do keep an eye on the cotter pin so it doesn't rust away on me and fall out. I did replace the floppy factory spring with the 4" Home Depot Everbuilt spring, which was a huge improvement over the stock POS spring. Now the stand retracts up against the stop, not hanging down from the frame.
John
Old Jun 17, 2024 | 11:54 AM
EasyTargetRN
The good thing about being in Albuquerque is there's little rain/snow/salt so parts like this tend to survive longer than when I was in NY.
Old Jun 17, 2024 | 06:26 PM
96hugger's Avatar
96hugger
My 96 did not have these, and I can't say for sure but I'm almost positive this is why my kickstand flew off while riding.
I'm *assuming* this is what happened because I have modified the suspension and it leans more than stock even, putting more pressure. May not be an issue with stock
Old Jun 17, 2024 | 06:49 PM
John Harper
On mine, the clevis pin inserts from the underside, and is held with a washer and cotter pin at the top. If that cotter pin rusts/falls out, the clevis pin can drop and bye-bye kickstand. I keep an eye on mine and should really just change it out for a stainless steel cotter pin. But it still looks serviceable last I checked, which wasn't too long ago.
John
