Parasitic drain
Old Sep 9, 2024 | 08:05 PM
Rounders's Avatar
Rounders
Originally Posted by John Harper
On second thought, I believe they likely do have a separate battery, in case a thief thinks disconnecting the battery will kill the alarm. So, maybe removing the Maxi fuse won't disable it? He may have to contact the dealer to see how to remove it, if possible. You wouldn't need much of a backup battery to sound a simple alarm.
John
I would think you could call the dealer. Would like to think something in the manual. I don't know how robust the security is. Second battery or just make noise until you disconnect the battery?
Wiring diagram would probably help too.
My2015, all you need to do is pull the maxi fuse and lights stop flashing. But it really isn;t much of secruity system, just need the fob to start.
Old Sep 9, 2024 | 08:18 PM
John Harper's Avatar
John Harper
IDK, my 1991 has none of these "newfangled" improvements. Three wires and a key.
John
Old Sep 9, 2024 | 09:10 PM
Von_Zipper's Avatar
Von_Zipper
Siren is optional, OP may not have it. But yes, if the siren is present then it will make noise, it has a Li battery built in. Unplugging and removing the siren is possible, it is not an integral part of security system.
Old Sep 11, 2024 | 02:58 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
The security needs to be deactivated by turning on the ignition with the fob present. hen pull the maxi fuse.
The little battery in the siren module is just for that. If the maxi fuse is pulled and the security system is active the siren will sound.
The battery in the siren module is a 9 volt nickel metal hydride type, NiMh, on my 2017 Sportster.
ap53
Aug 16, 2014 12:00 PM
bjv11383
Jul 5, 2012 06:16 PM
fardept
Mar 1, 2012 06:07 PM
Watch Guy
Mar 16, 2010 02:50 AM
cdestuck
Jan 28, 2010 02:29 PM
