Handlebar Problems
Old Sep 2, 2007 | 12:15 PM
flpops's Avatar
flpops
Default Handlebar Problems
My wife has a 1994, 883. Her bars slip down on her. I've got the allen screws as tight as I dare to go. Any suggestions? Thanks!
Old Sep 2, 2007 | 01:03 PM
Thumper26's Avatar
Thumper26
Default RE: Handle ar Problems
Sounds like someone may have put some 7/8" bars on the bike along the way (I believe stock for yours are 1", but verify that).
A quick fix would be to loosen the bars, wrap some duct tape 2 revolutions around the bars where they are pinched for tightening, recenter the bars, tighten, and use a razor blade to cut off any tape sticking out. Best bet would be to measure the bars. IF they are 7/8", and your bike should have 1" bars, get some new 1" bars...
Good luck!
Old Sep 2, 2007 | 01:06 PM
Dallastx's Avatar
Dallastx
Your better off shimming the bar with metal.
My2.
Old Sep 2, 2007 | 01:13 PM
flpops's Avatar
flpops
I just calipered them. They're 1".
Old Sep 2, 2007 | 01:39 PM
ecvjohn's Avatar
ecvjohn
Get a new top plate and risers if the bars are the correct size. If they have been loose for a while these parts may be just out of round enough to cause your troubles.
Old Sep 2, 2007 | 02:49 PM
6o66er's Avatar
6o66er
New top clamp, if they're aftermarket make sure they're knurled, if not, rough em up a bit in the center with a file and some heavy grit paper.
Old Sep 2, 2007 | 03:33 PM
flpops's Avatar
flpops
I'm going to try a new top clamp (that means a new chrome speedo bracket too). She was wanting a "Live To Ride" clamp. I wonder if she's been loosening them up to get new parts?
Old Sep 2, 2007 | 03:37 PM
6o66er's Avatar
6o66er
Quite possible....I know I'll break things on purpose sometimes to have an excuse to get something better, lol....
Old Sep 3, 2007 | 04:55 AM
dbleagle's Avatar
dbleagle
Take a soda can... cut two 1 inch wide strips out of it... take the bar clamp off wrap the aluminium around the bar trim it to size and put the clamp back on torque to specs... works every time...
Charlie D.
Old Sep 3, 2007 | 05:06 AM
bigtop1's Avatar
bigtop1
A strip of emery cloth wrapped around the bar might also help to do the trick.
