Clutch dragging with lots of cable slack when hot.
Old Nov 17, 2024 | 04:04 PM
H22man's Avatar
H22man
Default Clutch dragging with lots of cable slack when hot.
1989 4 speed 883. When the bikes cold, the clutch seems fine and the bike shifts okay but as the transmission gets got, the clutch lever slack increases and the clutch wants to drag sometimes - especially if I'm slipping it during low speed maneuvers. The transmission is noticeably harder to shift as well. Ive done the clutch and cable adjustments multiple times but it's still giving me issues. Any advice?
Old Nov 17, 2024 | 04:17 PM
TriGeezer's Avatar
TriGeezer
Cable slack has nothing to do with clutch pressure…well unless it’s extremely tight. Follow the adjustment procedure at the top/stickybin the c,Utah sub forum.
Old Nov 17, 2024 | 05:17 PM
John Harper's Avatar
John Harper
It appears you do have a spring plate in your 1990 clutch, but, oddly enough, I've never read of one failing like '91 and later. You also might consider the release bearing as well. Do a proper (by the book) clutch adjustment, and then you might have to take a look at the clutch pack and bearing. Good luck.
Of course, 86-90 bikes are quite different in some important areas than '91 and later, which is what most of us here have.
John
Old Nov 18, 2024 | 08:18 AM
Kenny94945's Avatar
Kenny94945
Interesting thread.
Heat is causing the clutch cable to lengthen (so to say) and causing the clutch discs to drag.
FWIW
I am not familiar with the year 1989.
Seems that the lever from the clutch cable (inside primary) end to the clutch assm alters its position.
The bearing may be the answer as our co-member writes.
Perhaps the clutch fiber plates are expanding or contracting from heat.
Could it be the clutch cable is lengthening from heat?
It may be time to disassemble for inspection of the clutch basket plus install 100% new clutch plates.
My vote: as a stopgap, change your trans oil to Harley branded and report.
Good luck, again interesting thread.
Old Nov 18, 2024 | 02:32 PM
crb2855's Avatar
crb2855
If it were me I'd open the primary and inspect the clutch and everything inside, One thing you don't want the clutch hub chewing up your stator and hub magnets. It doesn't's it sound like it but better safe than sorry. It's not that much trouble to check.
Old Nov 18, 2024 | 03:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If the clutch is not adjusted correctly and is slipping, it will overheat the clutch and it will feel like there is a lot of slack in the lever.
Try adjusting the clutch (when cold) in accordance with the service manual, if that doesn`t help, it will be time to disassemble and inspect the throwout bearing and the clutch plates, especially the spring (aka grenade) plate.
npn
Jan 16, 2023 12:43 PM
CT-Bagger
Oct 7, 2012 09:53 PM
kiethf
Jul 8, 2012 10:22 AM
spgtti
May 21, 2010 06:01 PM
Nellybelle
Mar 31, 2008 01:50 PM
