Well. I've been trying to tune this new motor and can't get it to stop pinging at WOT in 4th and 5th. Did a compression test and it's coming in at 225 psi front and rear. I talked with Hammer a few days ago and Dan said I may need to send the heads back and have a little more material taken off to lower the compression. Hammer said you really want to be below 200 psi to run on pump gas. Anyone have any experience with this?
Cams with more duration and lift to bleed off and lower your corrected would work. That said yours truly ran about 230 cold cranks in my shovel on pump 93 in Florida summer heat without pinging. Fire ring, combustion chamber eliminating any area for carbon build up was the key.
I assume these are slightly raised pistons with eyebrows and not flat pistons? The higher you can gain compression with the lowest dome was another key. You don’t want any dome blocking the spark from burning the mix evenly.
Is it EFI or Carbed? What carb? How many fuel circuits? Your probably in the neighborhood of 11.5:1 to 12:1 mechanical, don’t know what it is corrected with the cams you have?
I’ll get flamed for saying this. It’s the kinda snake oil I make fun of, but this one I believe in.. Fitch catalyst. These are like goofy lead pellets you drop in your tank. Laugh all you want but been using them in 12:1 street shovels for 30 years. They “do something” to help it from pinging.
My 93” Shovel made 115 lbs & 105 hp with a super broad high torque curve, 11.87 @ 112mph with a 130 street tire and I weighed 230 and am 6’5” of wind resistance. Cams varied, heads too. I was always looking for more. Don’t know your cams profiles? But in shovel world I ran relatively low durations.. like 260-280 and I ran high lifts 550-610. This bleed off a lot of that mechanical compression. Solid lifter probably come into play at the bottom too, hydraulics could help depending on how stiff they are or are not.
EDIT I missed you can only get 91 octane.. it does make a difference. I’d run additives probably.
