Do I Need to Program BCM 69992-12B
Old May 23, 2026 | 06:25 PM
javila4747's Avatar
javila4747
2nd Gear
Default Do I Need to Program BCM 69992-12B
Hi all. I have a 2016 Forty Eight and looking to replace BCM. I don't have a key FOB or alarm system. I'm planning to buy a used replacement. Does the replacement need to be programmed and is a simple swap?
Old May 24, 2026 | 07:36 AM
ftcmcb's Avatar
ftcmcb
I don't know about your 2016, however my 2012 requires the programming tool. Call a Harley Davidson shop and ask them about JUST reprogramming the BCM after you do the work. I have read a couple of on line articles that step you through a manual reprogramming. Very lengthy process.
Old May 24, 2026 | 08:21 AM
Iceman24's Avatar
Iceman24
Simple answers = yes (needs programming) & no (easy). If it was easy, everyone would be doing it. These bikes are rolling computers and just like any system board, changing the motherboard requires a bit of programming to mesh things into working order. Definitely do your research, and consider talking to professional.
Have to ask, why do you want to swap BCM? Any particular reason??
Old May 25, 2026 | 06:36 AM
WKNDS's Avatar
WKNDS
You might research if any of the motorcycle repair shops in your area have a
Technoresearch Centurion. I believe those are able to "marry" the new BCM...
https://technoresearch.info/diagnost...ion-super-pro/
hth,
T.
flhxi
Nov 21, 2024 09:33 AM
Lennie Wagner
11
Dec 26, 2016 08:47 PM
Sal C
Aug 8, 2016 08:58 AM
array
17
Apr 21, 2008 01:17 PM
customrider31
Sep 20, 2006 08:52 PM
