Netural
Old Nov 1, 2007 | 11:54 AM
FatBoy94's Avatar
FatBoy94
Default Netural
I have a 94 fatboy it has a hard time shifting into netural or almost impossable at a stop with the engine running. I can shift into netural easier as I pull up to a light but once I stop it is impossable. The clutch has just been replaced at the dealer and if anything it is a little harder to shift into netural now. Any ideas?
Thanks,
Bob
oops clicked wrong group
Old Nov 1, 2007 | 05:59 PM
SportyPig's Avatar
SportyPig
Default RE: Netural
I realize your error in posting, but I'd say the dealer didn't get the clutch properly adjusted when they made the replacement.
The clutch is dragging.
In other words, the bike is wanting to move forward eventhough you have the clutch pulled in.
Old Nov 1, 2007 | 09:15 PM
ride2tires's Avatar
ride2tires
Default RE: Netural
I am no monkey wrench... but this is where I would start.
Get the bike level and pop off the derby cover. Is the fluid level in the primary to high? Should be just to the bottom of the clutch assembly. If it is overfilled, can be a tough one to find "N".
If fluid looks good, pull the locking nut off the center of the clutch and turn it a 1/2 turn away from tension( dont quote me but I believe it would be clockwise).
Best of luck!
Old Nov 2, 2007 | 01:30 AM
JosephGarcia's Avatar
JosephGarcia
Default RE: Netural
ORIGINAL: ride2tires
Best of luck!
why does too much oil make it hard to find neutral? I had my clutch and primary fixed recently and i cant shift into neutral easily, but the clutch doesnt drag and shifting into other gears is nothing.
Old Nov 2, 2007 | 12:55 PM
ride2tires's Avatar
ride2tires
Default RE: Netural
ummm, not sure....
because the manual says so?.?.?[8D]
Sand850
EVO
21
Dec 19, 2016 07:17 PM
stevedrum4578
Jun 15, 2015 12:42 AM
TSheff
Jan 20, 2015 06:23 PM
lou1
May 19, 2008 03:00 PM
rgsamsel
Apr 21, 2006 12:41 PM
