Do lower temps. increase HP?
Old Nov 17, 2007 | 06:32 AM
Chopperz's Avatar
Chopperz
Default Do lower temps. increase HP?
I wonder if any significant ponies arise from lower temps? I know turbo's with inner coolers boast about more HP.But yesterday I was riding,it was about 35F and sometimes it feels like a little extra boost is there,but I could easily be fooling myself.Any idea's?
[IMG]local://upfiles/42833/5BCA9332A65D4979B16FA1DEC51D3A14.jpg[/IMG]
Old Nov 17, 2007 | 07:43 AM
drum412's Avatar
drum412
Default RE: Do lower temps. increase HP?
Old Nov 17, 2007 | 08:37 AM
rfranz1952's Avatar
rfranz1952
Not to be contrary, but cold air is more dense (thicker) than hot air. When gliders fly over flatland, they will look for plowed fields, because the warmth causes an updraft, and they will try to avoid green fields or irrigated land, because cool air sinks--it is heavier and more dense.
Cold air has more oxygen per cubic foot, so, if your bike was a little rich when it was warmer, then it is entirely possible that you could extract more power when it is colder. The extra fuel will burn more completely with cold air. In fact, if the tuning is right on at 90 degrees, and it drops to 30, the idle air mix may have to be opened a bit to keep the bike from getting the lean farts when the throttle is popped open.
However, I don't know how significant the change is.
Old Nov 17, 2007 | 08:57 AM
Chopperz's Avatar
Chopperz
Hmmm,well I have EFI.So I guess it automatically adjust's.
Old Nov 17, 2007 | 09:09 AM
cHarley's Avatar
cHarley
rfranz1952 is correct. Unfornunately, based on some recent posts here, the newer Sporty's with EFI may not be doing a great job of compensating. If you have a carbed bike, it's usually a matter of backing the mixture adj. screw out about a 1/4 turn during the cold months.
Old Nov 17, 2007 | 10:12 AM
JosephGarcia's Avatar
JosephGarcia
ORIGINAL: rfranz1952
This is what I was always taught as well.
i dont know where he came up with "cold air is thinner"
maybe thinner cold air at a higher altitude, but if you focus on the change of seasons in the particular place a bike is ridden then it is thicker usually
Old Nov 17, 2007 | 10:28 AM
HOTLAP's Avatar
HOTLAP
I agree with most of the above but it is true that cold air produces more horsepower, that's the whole point of an intercooler. Also cold gas does the same, many dragsters cool the fuel before the run or have onboard dry ice tanks to cool the fuel just before it goes into the engine.
Old Nov 17, 2007 | 03:42 PM
seikan1's Avatar
seikan1
I can tell a difference in how mine sounds and runs when it is cooler. That is why I love the cooler weather in the Phoenix area.
Old Nov 17, 2007 | 04:34 PM
AKsavage's Avatar
AKsavage
Cooler? weather in the Phoenix area?
Old Nov 17, 2007 | 06:20 PM
SportyPig's Avatar
SportyPig
Correct, and the change can be signficant. I ride in temps from a high of over 105 and the low range of 15. The change in huge!!
