Ignition system which one?
Old Jan 5, 2006 | 12:29 AM
k2rmx.rob's Avatar
k2rmx.rob
Default Ignition system which one?
Hello to all, Ok i want a Ignition system which i'll be able read & write to the device with a laptop or a palm, and have lots support, something simple that does not take long to learn (dyna, crane, se, other) Which one ???
MY Gallery
Old Jan 5, 2006 | 01:29 AM
AZFlyingDiver's Avatar
AZFlyingDiver
Default RE: Ignition system which one?
Daytona Twin-Tec TC-88A.
Check out this thread for some interesting info specific to Sportys:
http://www.xlforum.net/vbportal/foru...ad.php?t=18702
Good luck!
Old Jan 5, 2006 | 02:11 AM
WarriorHD's Avatar
WarriorHD
This is from a post that I saved from MegaHDman. I checked out this S&S ignition and it is nice. Plan on going to it myself in the future....
You can gain or lose hp with any engine's ignition timing curve. Thats nothing new, I doubt NRHS found out that on "accident". It all depends on how well the ignition map is dialed into the engine on hand. Daytona Twin tecs TC88A modle is nice and a good buy for the money but if Im going to be doing an all out performance build with a carbureted motor I would choose S&S's IST ignition as a first choice. It is hands down the best iginition module on the market. Its $$$, but worth every penny. It adjusts your ignition on the fly for best possible performance without pinging the engine. So if you ever change parts,load on the bike(like 2up riding), even gas octane, it will change the timing for optimal performance. No tinkering around needed. I used to run a DTT TC88A module, and it worked well,but I was contantly tinkering with the ignition map depedning on how I was using the bike, then I switched over to the IST, and it was a big upgrade.
Here's the link to the original post:
https://www.hdforums.com/m_186571/mp.../tm.htm#187725
Old Jan 5, 2006 | 02:58 AM
AZFlyingDiver
Hey WarriorHD - any sources for the S&S IST for 04+ Sportys? I was familiar with S&S but then couldn't find anything more. I'd like to look into it myself! Thanks...
Old Jan 5, 2006 | 11:07 PM
WarriorHD's Avatar
WarriorHD
ORIGINAL: AZFlyingDiver
I had found an online write up about a month ago and book marked the page on my old laptop which is now crapping out on me. Im going to try to pull some stuff off that laptop this weekend so if I get into it, I will grab the link for you. If not, I will search around...I know there is some info out there on the S&S ignition.
rouskie
Ironhead
Mar 20, 2017 10:14 PM
HDF Tech
Engine Mechanical Topics
Mar 12, 2012 05:24 PM
gargoyle
Mar 15, 2008 04:52 PM
SmokinEd
Sep 8, 2007 10:36 AM
kansasroadking
Aug 21, 2006 02:52 AM
