Changing Oil
Old Jan 12, 2008 | 08:48 PM
cpa55's Avatar
cpa55
Default Changing Oil
Wife showed up with 3 quarts of syn and an oil filter and wants me to change her oil. I don't have a clue how to change the oil on a Sportster. Any help would be appreciated so we can ride tomorrow.
Thanks,
David
Old Jan 12, 2008 | 08:55 PM
anubisss's Avatar
anubisss
Default RE: Changing Oil
Find the hose that comes out of the oil tank and is clamped to the left (if you are sitting on the bike) side of the bottom of the frame. Unclamp from the frame. Use a regular screwdriver to reove the plug at the end of the hose. Insert hose in oil pan. Undo oil filler plug. Remove oil filter but not without putting some tinfoil or something under the filter to catch all the oil in it. Put on new filter. Not too tight. I believe the manual says half turn past where it starts to get tight. reinstall plug at the end of the drain hose. Reclamp to the frame. Pour oil into oil tank. I can't remember how much it takes and I'm too lazy to get the manual out. By the way having a manual might help at a time like this. That is for the crank case. Then you gotta do the primary/transmission too. It's in the book. Good luck. When I first got here no one would tell me how to do an oil change.
Old Jan 12, 2008 | 09:16 PM
Stefan's Avatar
Stefan
ORIGINAL:
1. Find the hose that comes out of the oil tank and is clamped to the left (if you are sitting on the bike) side of the bottom of the frame. Unclamp from the frame. Use a regular screwdriver to reove the plug at the end of the hose. Insert hose in oil pan.
2. Undo oil filler plug.
3. Remove oil filter but not without putting some tinfoil or something under the filter to catch all the oil in it. Put on new filter. Not too tight. I believe the manual says half turn past where it starts to get tight.
4. reinstall plug at the end of the drain hose. Reclamp to the frame.
5. Pour oil into oil tank. I can't remember how much it takes and I'm too lazy to get the manual out.
6. Then you gotta do the primary/transmission too.
Notes:
1. On the pre-2004 models there was a bung on the frame in front of the rear tire. A screwdriver is all you need. Just leave a pan under the hose.
2. This allows air into the oil tank and helps to drain the oil
3. A second oil pan is needed to catch all the oil, not just a rag or tinfoil. I normaly use an old t-shirt sleeve as a scaraficial rag to assist in keeping the oil from getting over the case.
I've been hand tightening the filters for .... I don't remember exactly. Perhaps 20,000 miles, at least. Hand tight works fine. Just keep in mind how hard it is to remove the filter if you use a wrench to tighten it.
4. Just put the plug back in. Don't tighten it or put it on the frame yet. I will explain after the next step.
5. It takes just under 3qts of oil, or just more than 2.5 qts. As long as it shows up on the dipstick you are good.
5 1/2. After puting in your first quart of oil go back under the frame and remove the plug from the hose untill you see some oil. Otherwise you will have an airbubble in the system that can cause some problem the book will explain if you don't believe me.
6. Tranny is only done every 5k miles. You will want the book for this one! Remember your T27.
Old Jan 12, 2008 | 09:19 PM
Sporty07's Avatar
Sporty07
i agree with having the manua, it will show and tell you how much oil to add and how to change....l
Old Jan 12, 2008 | 09:25 PM
cpa55's Avatar
cpa55
Thanks guys! I will get a manual, I just needed to know how tonight so we can ride tomorrow. Any other tips will be appreciated.
Thanks again,
David
Old Jan 12, 2008 | 09:26 PM
Dorkman's Avatar
Dorkman
First, check to see if the synthetic is certified for CF, CF-4, CG-4 and CH-4 use. Automobile oil often isn't. Also, it is the correct viscosity for your bike.
Old Jan 13, 2008 | 04:37 AM
cHarley's Avatar
cHarley
TWO CORRECTIONS TO ABOVE POSTS:
1: You need to add 4oz. of oil to the new filter before installing it.
2: Unless it's a 07up sporty, the manual does NOT list the correct oil quantity for an oil change. The quantity
listed in the manual is for a factory new dry engine. An oil change takes just under 3 quarts counting the
4 oz. that go in the filter.
Old Jan 13, 2008 | 10:08 AM
DrPlastic's Avatar
DrPlastic
What letter size oil filter wrench is needed to remove the oil filter? A size F is too small.
Old Jan 13, 2008 | 10:11 AM
anubisss's Avatar
anubisss
Thanks for psoting about the air bubble Stefan. I was not aware of that. You learn something every day.
Old Jan 13, 2008 | 01:59 PM
Stefan's Avatar
Stefan
Thanks for psoting about the air bubble.
Okay, you got me curious enough to look it up. This is in the 2002book, there is a CAUTION: "This action removes air from the drain hose and prevents the possibility of oil pump cavitation."
I did not do this untill looking it up in the book w/no problems. I'm not sure if the stealership did it either. It's something I do now but as shown above I forgot the reason for doing it.
cHarley made the other point, I sometimes forget to put a good amount of oil in the filter which helps get the pressure up when first starting.
Bluraven
Sep 12, 2021 04:18 PM
pontiac69
Apr 29, 2011 11:41 AM
vonzip
EVO
Oct 3, 2009 01:23 PM
broadwayjoe
May 18, 2007 04:04 AM
Tx883c
Nov 26, 2005 03:28 AM
