FUEL PACK INSTALLATION PROBLEMS!!!!!!
Old Jan 19, 2008 | 10:04 PM
evilscotsman's Avatar
evilscotsman
Default FUEL PACK INSTALLATION PROBLEMS!!!!!!
I need some serious advice on installing aV & H Fuel Pack on my 07 Sporty. I'm ready to stick this thing up somebody's a$$ right about now. The help video on the website makes it look soooo easy! That's a crock of $hit. I've been trying to get it installed for 3 hrs now and there just isn't enough room for it to fit. PLEASE GIVEME SOME POINTERS IF YOU HAVE DONE THIS INSTALL!!I'll be checking on this post every half hour. All advice is welcomed. Thanx peeps.
-Evil
Old Jan 19, 2008 | 10:28 PM
nevets61's Avatar
nevets61
Default RE: FUEL PACK INSTALLATION PROBLEMS!!!!!!
I agree, its a ****.... I installed mine but it took rerouting some of the wires to allow the FP to fit under the frame tube above the battery. Was still VERY tight. I wish I could offer you more insite. I too spent an agravating couple of hours... Took a break, drank a couple of beers and went back to it... somehow I managed to move the wiring just right and it fit... But it was TIGHT!!!
Be patient. Once in its worth it... works as promised..
Good luck.
Old Jan 19, 2008 | 10:57 PM
ridinloud's Avatar
ridinloud
Stage I
its a very tight fit between top of battery and frame tube,i had to move around some wiring abit to make it fit.also disconnect ground
cable from engine and slide battery in and out but it will fit
Old Jan 20, 2008 | 12:07 AM
YodaddyKeith's Avatar
YodaddyKeith
Send that sucker back!
Try the PCIII USB!
It comes with a new tray to replace the one that holds the factory ECM....The tray is deeper and the PCIII mounts under the ECM it a fitted pocket.....It takes 20 minutes total to install and load fuel map, then go hit the road.
I just installed mine 2 days ago and it's killer.
Old Jan 20, 2008 | 01:40 AM
p2pants's Avatar
p2pants
I had a indy shop install mine. I'll take pic and upload it so u get an idea where the tech put mine. Mine isn't under the seat but rather overtot he left side with the ecm. Was like $170 just for labor but I had to input the program myself. Inputing the program was easy part.
I got SE AC, V&H race tuner, and D&D slipons.
Old Jan 20, 2008 | 05:25 AM
HarleyScuba's Avatar
HarleyScuba
Dude,
Sorry for your pain, but your post made melaugh so hard ithurt!
Again, sorry.
I haven't had the pleasure of trying such. I hope my karma doesn't snap back on me too hard for laughing.
I wish you the best of luck.
Still laughing...
Old Jan 20, 2008 | 07:52 AM
chornbe's Avatar
chornbe
*chuckling* They really do run fine stock.
Old Jan 20, 2008 | 08:42 AM
DrPlastic's Avatar
DrPlastic
That PCIII and the replacement tray are fine IF you do not plan on lowering your bike. If you do the tire will wear a hole in the tray and your ECM.
Old Jan 20, 2008 | 08:53 AM
evilscotsman
Okay, I've calmed down now and I'm ready to go back out to the garage and into the trenches. I guess patience is the word for the day. I'll keep everyone posted. All tips and pointers are still welcomed. Thanks guys (and gals).
- Evil
Old Jan 20, 2008 | 11:06 AM
txoval's Avatar
txoval
Not sure how much lower you plan on going, but I haven't had any rubbing issues with the PCIII on my Nightster
ORIGINAL: DrPlastic
