replacing gearcase cover help
Old Jan 18, 2006 | 05:53 PM
JKDJose's Avatar
JKDJose
Default replacing gearcase cover help
I am trying to replace the gearcase cover on my 91 sportie and I am having trouble. I am replacing the cover because the timing standoffs that hold the timing cover on were completely rotted away and snapped off, so I am trying to repair it.
Beside removing the screws that hold the gearcase cover on, is there anything else I have to do to remove it?
I noticed that there's a sensor that is attached to the timing cup that rotates.
I tried removing it today but it feels like it's getting caught on a stop or something.
Please help.
Old Jan 18, 2006 | 08:35 PM
Wolhar's Avatar
Wolhar
Default RE: replacing gearcase cover help
From your description you are trying to remove the Primary Cover (left side sitting on bike) if that is correct, you must remove Derby cover and disconnect clutch cable, and you have to loosen primary chain adjuster and let all the tension off the primary chain. on a '91 model you may have a worn shoe on the primary chain adjuster that is "holding" it to the chain so to speak, do not continue with this project unil you PM TCSTD or pococj on this site. Also check th DIY page.
Old Jan 18, 2006 | 08:39 PM
pococj's Avatar
pococj
Rusty, he's talking about the cam cover. I've never had a late model Evo Sporty apart, so I ain't gonna be much help. I will submit that if you're gonna go that far into the thing, you need a service manual, like yesterday!
Old Jan 18, 2006 | 08:41 PM
JKDJose's Avatar
JKDJose
I have the both the clymers and haynes and all they say is to remove the bolts and take the cover off which is not happening. I need to know if the manual is missing something else.
Thanks.
Old Jan 18, 2006 | 08:54 PM
Wolhar's Avatar
Wolhar
Wrong, dude this is a major piece of work. those manualas are missing a bunch.
ORIGINAL: JKDJose
Thanks.
Old Jan 18, 2006 | 08:55 PM
pococj's Avatar
pococj
Go to the ignition section of the manual. I have an old 1979 Sporty manual that tells how to remove the ignition stuff, but it is only in the ignition section and not in the section that covers removing the gearcase. That stuff has to come out before the cam cover can come off.
Old Jan 18, 2006 | 08:59 PM
JKDJose's Avatar
JKDJose
Thanks Pococj. I found it. I have to remove the ignition sensor and then the bolt behind it. It was in the clymer's I just needed some motivation to keep looking. Thanks a bunch.
Old Jan 19, 2006 | 01:02 AM
Wolhar's Avatar
Wolhar
Skips Long Distance Road Service strikes again! Dude you amaze me, I couldn't begin to remember all the places to look s*** up that you do!
Buttersbeanball
Nov 2, 2018 08:07 PM
Klymax Kustoms
Mar 24, 2010 07:21 PM
gilmour68
May 14, 2009 09:34 PM
ralfareno
Oct 26, 2008 07:34 PM
carguy9497
Oct 7, 2006 11:45 PM
