Baffles Installed
Old Feb 4, 2008 | 11:21 PM
Ric27's Avatar
Ric27
Default Baffles Installed
I installed Thunder Monster baffles in my drag pipes this evening. I also got the title transfered today. So now I have a licence plate. I wont have to feel like such a 1%er when I'm puttin' around the hills and hollows. My rear brake linkage in still rubbing the front exhaust pipe in the bend. not as bad but it's not right.
Ric
Old Feb 4, 2008 | 11:26 PM
Biker Trash's Avatar
Biker Trash
Default RE: Baffles Installed
In time with a little patients and elbow grease you'll get it right! Sounds like you are lovin it though!
Old Feb 4, 2008 | 11:39 PM
GothMetalGuitarist's Avatar
GothMetalGuitarist
ORIGINAL: Ric27
Ric
Is the exhaust installed correctly or is your brake lever bent? If your exhaust isn't installed correctly you could have an exhaust leak and thats not good for the motor. It is always best to loosen your header bolts, your exhaust mount bolts, get it in the right position and tighten bolts a little at a time until its all snugged up.
Old Feb 5, 2008 | 08:43 AM
Ric27's Avatar
Ric27
The thing is the forward control peg and the pipe are so close together that there isn't enough clarence right at the bend of the pipe.
I did grind off a sharp corner off the end of the linkage arm thinking that would take care of it. Now it just touches when applying the brake rather than scraping as before. I think it got the pipe back on correctly. I was very careful.
Ric
cgmartine
Nov 13, 2013 12:09 AM
phidoux
Sep 17, 2011 01:35 PM
lhorns13
Engine Mechanical Topics
Jun 25, 2010 08:13 PM
sportster 883
Jan 2, 2009 06:42 PM
tmitchellof PG
Exhaust System Topics
Nov 27, 2008 05:30 PM
