lolly pops in exhaust???
Old Sep 17, 2011 | 09:45 AM
phidoux's Avatar
phidoux
6th Gear
Default lolly pops in exhaust???
I just traded in my sporty on a 07 wide glide that had after market exhaust on it with baffles.
I remove the baffles in it and need to know if i need to have a little restriction on the exhaust or not.
I did all the wrenching on my old bike but am new to the dyna family as well as the fuel injection type motor.
any help would be appreciated.
Thanks
phidoux
Old Sep 17, 2011 | 09:49 AM
twistr's Avatar
twistr
No need to install the "lolly pops"..baffles are providing back pressure
Old Sep 17, 2011 | 10:03 AM
phidoux's Avatar
phidoux
6th Gear
twistr
I removed the baffles and am running straight pips now.
Old Sep 17, 2011 | 10:26 AM
JohnC FXDX's Avatar
JohnC FXDX
I believe he is saying that he removed the baffles. You do need some back pressure for Best performance. I added lollipops into my drag pipes the other day because I wanted to take some bite out of the exhaust tone and add some back pressure. I used a stainless 1/4" eye bolt? I first tried it sandwiched between two washers to make it a solid disc. It quieted down quite a bit, but I felt it did not pull as hard. It may have been too restrictive. I then turned them 90 degrees so it will just split the flow and it performed a lot better. It actually still muffled the noise a little too. I may try the eyebolts without the washers perpendicular to the pipe and see how that does. As it is know, I can also change the angle by turning them to change the flow and sound. It is an easy fix unTil I can get a good 2-1 pipe.
Old Sep 17, 2011 | 10:35 AM
Lorance66's Avatar
Lorance66
lollipops are basically what BCT baffles are and they are some of the best money I ever spent on my bike. And yes, that little bit of back pressure made all the difference as I could not help but test my bike with the baffles out
Old Sep 17, 2011 | 10:45 AM
Robbie13's Avatar
Robbie13
LOSER
I have the BCT baffles in mine too. My understanding is the FI needs some amount of back pressure to run well.
Old Sep 17, 2011 | 11:11 AM
Steel Steed's Avatar
Steel Steed
Post pics! Running V&H quiet baffles in my V&H slip on's... sounds great and performs nicely. Also have SEPST and Arlen Ness Big Sucker to complete the stage 1. I didn't test without the baffles, but I've read many times you'll get better performance with some back pressure.
Old Sep 17, 2011 | 11:49 AM
Foxster's Avatar
Foxster
Just a thought...its not actually back pressure but reversion waves that are at work here. Don't matter though, lollipops don't know the difference .
Old Sep 17, 2011 | 01:31 PM
twistr's Avatar
twistr
Originally Posted by phidoux
twistr
My mama use to always say that I never paid attention...guess she was right
Old Sep 17, 2011 | 01:35 PM
SteveO-ll's Avatar
SteveO-ll
I like the way you think about this subject.
NCollins85
Sep 10, 2016 11:38 AM
skipperhd1
Mar 19, 2014 11:02 PM
JCK
May 5, 2010 02:37 PM
TennMan
Jul 25, 2008 02:30 PM
alrom999
May 1, 2008 07:36 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
