Loctite opinion?
Old Feb 15, 2008 | 11:38 AM
Stefan's Avatar
Stefan
Default Loctite opinion?
I'm doing this thread for discussion. I did just put it in the 100k thread but thought it might be a good thread on its own for discussion by those who have experience with Loctite.
While reading thru some other posts I realized that I don’t use Loctite. In fact I often oil/grease hardware in order to prevent corrosion and aid in removing the hardware later on. So far I have only lost one screw from my air cleaner cover, which I knew was loose & I expected to see it fall out. I often use a torque wrench but most hardware is good-n-tight (1/4 turn past fingertight).
Similar to my using dino oil I’m not saying it is THE way to do things, just something I found interesting & thought I would share.
Old Feb 15, 2008 | 12:07 PM
DeJavu's Avatar
DeJavu
Default RE: Loctite opinion?
The only place I lube the threads is on the head bolts, I use Loctite on any bolts I can't put a nylock nut on. I like the nylock a lot and have even used them on my exhaust manifold studs for the last 12 yrs, and reused them without a single loose nut.
The nice thing about Loctite is you don't have to reapply it each time, it lasts and works for many assy/disassemblies. Loctite seals and lubes the threads and prevents corrosion. Great stuff.
Old Feb 15, 2008 | 12:11 PM
pahunter's Avatar
pahunter
I use finger nail polish works just as good and a whole lot cheaper jmo. Ride Safe Doug
Old Feb 15, 2008 | 12:13 PM
jmarkle's Avatar
jmarkle
I use the blue stuff. It holds quite well but still can be removed.
Old Feb 15, 2008 | 12:48 PM
MosesJJN's Avatar
MosesJJN
I'm loctite intolerant.
Old Feb 15, 2008 | 12:49 PM
Wecroft's Avatar
Wecroft
The only thing that saves you is thea fact that you ride an 883, with very little vibration. Try installing anything on a bigger bike without a drop of the blue stuff on the threads and you'd better have a good supply of bolts and accessories back in the garage.
Old Feb 15, 2008 | 01:27 PM
valveguide's Avatar
valveguide
Blue loctite and dielectric grease must be next to me at all times.
Someone else said it , if it don't have a lock nut the loctite is essential .
Old Feb 15, 2008 | 01:39 PM
Gigawitz's Avatar
Gigawitz
If you don't like the sound of misc. parts falling off your bike,I would locktite everything with blue.
Old Feb 15, 2008 | 02:13 PM
cHarley's Avatar
cHarley
ORIGINAL: Stefan
There was a thread here a couple of months ago where someone had a non-loctited screw come loose on his A/C. It got sucked in the carb and took out his motor. A valve if I remember correctly.
It's Blue Loctite for me.
Old Feb 15, 2008 | 02:23 PM
Ricochet2's Avatar
Ricochet2
Loctite also makes many oftheir products in the form of a chapstick tube, like a wax twist bottom and out with the blue.Works great unless you need the stuff to wick,(sticks don't wick). convenient, less mess, easy storage.
