Loctite opinion?
Old Feb 15, 2008 | 02:31 PM
YodaddyKeith's Avatar
YodaddyKeith
Default RE: Loctite opinion?
Locktite cannot be reused.......it's chemical makeup is such that it only sets up when NOT exposed to Oxygen.....So in the bottle, it remains liquid cause 02 is present in area above the liquid, but once trapped/confined to the super tiny area provided by the fastener threads where 02 is not, it sets up.....The color determines how hard it sets....Red locktite is considered perminant whereas blue allows stiff breakaway torque, but should allow you to remove fastener without breaking it.
I served 20 years on nuclear submarines as a mechanic.....We torqued everything to specs and locktite is in my blood.
While we are on the subject, fastener torque is an indirect way to measure bolt stretch....Bolt stretch provides clamping force....All fasteners should be wirebrushed clean to remove old thread sealants before torqueing so you can get an accurate reading.....Threaded holes should also be chased clean with taps to remove old thread sealant for the same reason.....certain fasteners should be lubed before torqueing......bolt torque is a science with no room for old wive's tales.
Old Feb 15, 2008 | 07:05 PM
Stefan's Avatar
Stefan
Let's go with bolt torque.
If your bolt is steel and the threaded hole is aluminum, then you will be distorting the threads in the aluminum & going to need a Helicoil very soon. You can set a torque spec low and not elastically distort the threads, by keeping the spec in the plastic rangeyou can reuse athreaded fastenerwithout worrying about it being worn out. Know your ft-lbs from your in-lbs!
Wrenching a motorcycle is not the same as working to ASME code Section III.
http://ap1000.westinghousenuclear.com/index.html
Old Feb 15, 2008 | 07:09 PM
farns's Avatar
farns
I use loc-tite, I use a torque wrench for critical things like head bolts etc.
I cheat and do what I have to depending on what I have on hand when doing a repair.
Old Feb 15, 2008 | 07:17 PM
x2lee's Avatar
x2lee
I use it on EVERYTHING, its great stuff. My bike would fall apart everytime I rode it if it wasnt for locktite
I have had women tell me they wanna take my footpegs home it vibes so good. Thing about LT is you just need a dab and just at thetip of the thread. You can screw up stuff bad using too much locktite especailly if its red...
ORIGINAL: farns
Old Feb 15, 2008 | 07:31 PM
Dorkman's Avatar
Dorkman
Loctite is cheap insurance. Clean the threads, one swipe and you are done.
Old Feb 15, 2008 | 07:43 PM
SportyPig's Avatar
SportyPig
I buy locktite blue by the case. Also use anti-seive cream for those steel to alumnium (and other not related metal) bolts, and screws.
Old Feb 15, 2008 | 08:29 PM
RATROD HOG's Avatar
RATROD HOG
OK lets all do a little test now:
get your pens and paper ready
TEST=1
get any size bolt and nut laying around and put some blue loctite on it (chap stick kind )
just put nut on end of bolt ,screw on till flush
then let dry over night and then you will have your answer
sailmotion
General Topics/Tech Tips
Mar 29, 2017 10:25 AM
deadhawg
Oct 16, 2015 12:26 AM
jaxdwg
Apr 23, 2014 05:16 PM
rojuwi
Oct 26, 2012 10:53 AM
bzxgdk
Aug 1, 2011 01:52 PM
