ORIGINAL: x2lee
Perhaps you should re-check your calculations. A 1200 at 5475 is 122 mph
I had the Rear Wheel Sprocket (61t) value in the Clutch Sprocket (56t). I'm still not getting 122 mph tho. What are you using as the grear ratio in 5th gear?
ORIGINAL: x2lee
The rear wheel sprocket is 68T on mine. Stock on 04up USA.
herr monk...never thought of the speedo being off a bit. im sure they are not dead accurate....fast enough for my one time deal anyway,,,just wanted to see what it had. brian
I would assume that Harley, like the cage makers, inflates the speedo by the permitted tolerance. So, if your speedo says 100, you're probably doing about 95. I've checked my cages (of various foreign and domestic makes) and they are remarkable consistent--5% high.
It's a great thing.You think you're getting better gas mileage, longer engine life, better performance..... all at the same time.
