Battery Question
Old Mar 9, 2008 | 07:44 PM
midav's Avatar
midav
Default Battery Question
Would discharged or charged below 50% battery make the engine turn but not start up?
I've installed new handle bars, grips, controls wiring - all electrical systems work fine (turn signals, lights, brake lights, etc), but the bike won't start. It turns, but doesn't start. I have about a gallon of gas, fuel pump makes the sound, but that's it. The bike was sitting in the garage without battery tender for a few months, so I'm hoping that it's the battery.
what do you think?
Old Mar 9, 2008 | 08:28 PM
valveguide's Avatar
valveguide
Default RE: Battery Question
Are the plugs wet ?
You really aren't supposed to do this ? a lot , but starter fluid.
If if starts with that after a squirt your fuel is plugged somewhere .
Old Mar 9, 2008 | 08:37 PM
midav's Avatar
midav
I'll try that as a last resourt. I'm still leaning toward "discharged battery". I rode the bike back in the beginning of December once, and after that it was sitting in the garage. Look like I'm off to buying a battery tender in the morning...
Old Mar 9, 2008 | 08:52 PM
SpursDarkrider's Avatar
SpursDarkrider
any 2 amp charger will work to charge the battery back up. The tender will be good afterwards to keep the battery charged during periods of storage
Old Mar 9, 2008 | 08:57 PM
midav's Avatar
midav
so the tender doesn't actually charge it? it just keeps it alive?
Old Mar 9, 2008 | 09:00 PM
SpursDarkrider
im pretty sure a tender will charge it eventually, depends on what type of tender you get. Some also have a 10 amp setting to charge quicker.
Old Mar 11, 2008 | 08:30 AM
midav's Avatar
midav
It wasn't a battery... replaced spark plugs and started up perfectly. Weird that I had to change spark plugs on a bike that's about 8 months old
slvrscoobie
Mar 20, 2017 05:12 PM
sammer4u
Jan 4, 2013 05:48 PM
dohadex
Feb 16, 2011 10:52 PM
twhill3
Dec 11, 2010 12:17 PM
johnnychum
Mar 25, 2008 07:16 PM
