Neutral Question
Old Feb 1, 2006 | 03:45 PM
steve1173's Avatar
steve1173
6th Gear
Default Neutral Question
Starting to get back into riding after a long break. Just went from a Buell Blast to a 06 883 Sportster. Question on neutral, am having a hard time getting it into neutral at a stop. While moving not much problem but at a stop almost impossible. Any ideas.
Old Feb 1, 2006 | 03:49 PM
HeatherC's Avatar
HeatherC
Default RE: Neutral Question
I have the exact same problem with my 1200C. I can easily get it into neutral if the bike is rolling but it is difficult at a compete stop. Sometime I find if I rock the bike back & forth a few times then try I can hit neutral.
Old Feb 1, 2006 | 03:50 PM
AZFlyingDiver's Avatar
AZFlyingDiver
I had the same problem at first. If you're holding on to the front brake while trying to nudge the gearshift into neutral, it might be difficult. Try rocking the bike very slightly front to back while getting into neutral - it should slip in much more easily that way. Good luck!
Old Feb 1, 2006 | 03:59 PM
alexcue's Avatar
alexcue
man, i thought it was just me. My last non H-D bike had a "neutral finder". It basically never missed.
This one takes a few tries to get it right, and i thought i was just doing something wrong. Rolling to a stop sign i usually get it right, but if i stopped maybe one in four tries. I feel like a dork, going up and down as gently as possible to get it to go into neutral.
Old Feb 1, 2006 | 04:50 PM
Rhubarb's Avatar
Rhubarb
If you leave it in gear when you stop, you have the chance to get out of the way before you get rear-ended. In neutral, chances are you will not move in time.
Maybe HD was looking out for your well being when they made it hard to shift from a stop. [&:]
Old Feb 1, 2006 | 06:12 PM
Thumper26's Avatar
Thumper26
Unfortunately, Rhubarb makes a lot of sense in what he says...
Thumper26
Old Feb 1, 2006 | 06:13 PM
alexcue's Avatar
alexcue
Point well taken! but sometimes it's nice to just relax a bit at the light, while watching your rear view mirrors for some blue hairs
Old Feb 1, 2006 | 06:14 PM
HeatherC's Avatar
HeatherC
BUT I'm not talking about at a stop light. I'm talking about in my driveway, my garage, a parking lot. There are other times you need your bike in neutral and it's hard to get there.
Old Feb 1, 2006 | 06:19 PM
Thumper26's Avatar
Thumper26
Those are about the only times I search for and want neutral - when I'm about to dismount and walk away from the bike...
Thumper26
Old Feb 1, 2006 | 06:24 PM
HeatherC's Avatar
HeatherC
I'll admit after a long day of riding I am looking for neutral every chance I get because my clutch is so hard to pull after riding all day and messing with it I am praying not to have to hold the clutch in....that's usually when it's REALLY hard to find neutral.
