Choke cable replacement?
Old Mar 13, 2008 | 11:46 PM
Biker Trash's Avatar
Biker Trash
Default Choke cable replacement?
Ok so I removed the cowbell horn today and was relocating the choke **** to where the cowbell used to be. As I was tightening the nut on the back the plastic threaded area snapped. [:@]
Now I get to replace the whole shebang. Has anyone had to do this yet? How hard is it to do? Also are there any aftermarket ****/cable assemblies available that look better than the factory black one? I don't want just a cover since I need a whole assembly anyhow.
Thanks,
E.
Old Mar 13, 2008 | 11:50 PM
6o66er's Avatar
6o66er
Default RE: Choke cable replacement?
J&P has the whole assembly for abouy 17 bucks, they're aftermarket and use a tube instead of just the cable shielding.
As far as replacing it....really easy.
Disconnect your fuel line and VOES line, pop the carb off the manifold, loose the nut that retains the choke assembly on the carb, slide it out, put the new one on (you'll see how it's attatched to the needle...when it comes out) and just work in reverse order.
Takes about 15 minutes if you got everything you need.
Old Mar 13, 2008 | 11:56 PM
Biker Trash
ORIGINAL: 6o66er
Thanks 6o66er,
I think I've been every part of that carb except for the choke cable area. After this I'll know the carb from top to bottom.
Old Mar 14, 2008 | 12:05 AM
SportyPig's Avatar
SportyPig
My plastic **** broke, and they had to replace the entire cable. It was a warranty thing, so I didn't do the work, but I watched. It was a fairly simple process.
jerseydevil63
Aug 14, 2014 08:43 PM
jbubbalee
Jul 28, 2012 07:42 PM
bharvey60
Apr 17, 2012 09:49 AM
patsfan05488
Mar 28, 2011 08:27 PM
Classic Eagle
Carburetor Related
Aug 31, 2009 08:28 PM
