which oil to use with Progressive fork springs?
Old Mar 17, 2008 | 04:03 PM
  #31
chornbe's Avatar
chornbe
Default RE: which oil to use with Progressive fork springs?
Progressive rate springs (brand name aside) work fine with the emulator valves if you use ones that are wound to a high(er) spring rate - certainly higher than stock. The Harley springs (at least the ones in my sportster) are progressively-wound springs but are too soft. They would absolutely be a detriment with the emulator valves.
Old Mar 17, 2008 | 06:55 PM
  #32
1200c's Avatar
1200c
One thing to remember about the cartridge emulators is that you have to disassemble the forks to make an adjustment to them I don't know about the rest of you but I only want to do that once.So unless your Duck hunting in the canyons probably not worth it.
I am pretty sure there is a way to make them adjustable externally.
Old Mar 17, 2008 | 07:56 PM
  #33
SPECIAL ED's Avatar
SPECIAL ED
The emulators themselfs are adjusted at the time of installation you can add some kind of preload adjuster fork caps that can be adjusted externally but not the emulators. If you're a racer trying to shave a few tenths of a second off your lap time probably worthwhile but I've never felt the need to adjust mine.
subgunner
Sep 25, 2018 11:38 PM
vladt
May 16, 2009 07:10 PM
BluePotato
Jul 8, 2008 09:00 PM
cHarley
Sep 7, 2007 06:37 AM
ryback
Jul 19, 2007 05:57 PM
