Has anyone tried this mod when installing an aftermarket breather system.....
Old Mar 25, 2008 | 05:43 PM
DrPlastic's Avatar
DrPlastic
Default Has anyone tried this mod when installing an aftermarket breather system.....
I was having an epiphany of sorts last night whilst I was showering. I was wondering if anyone had thought about routing the breather tubes from rocker boxes back to the oil tank when installing an aftermarket AC and breather system? It would make sense and an easy mod for me at least and it would allow oil that invariably collects in the line(s) to be rerouted back to the oil system and not making a mess on the engine.
Hmmmmmm
Inquiring minds would like to know............................
Old Mar 25, 2008 | 05:52 PM
6o66er's Avatar
6o66er
Default RE: Has anyone tried this mod when installing an aftermarket breather system.....
I think it would be more work than it's worth, to be honest. You wouldn't really acquire that much to make a difference. Good Idea though.
Old Mar 25, 2008 | 05:58 PM
cHarley's Avatar
cHarley
Just guessing, I haven't measured it, but the oil bypass line would have to run from the breather bolts at a slight downhill angle, towards the oil tank and enter the tank above the FULL oil level height in the tank. Once the mist gathers as a liquid in the line it would have to be able to freely flow downhill.
Old Mar 25, 2008 | 06:02 PM
The Baron's Avatar
The Baron
Just run the breather tubes up instead of down, then the oil will run right back into the motor when you shut 'er down.
Old Mar 25, 2008 | 06:03 PM
x2lee's Avatar
x2lee
dump it on the ground...
Old Mar 25, 2008 | 06:45 PM
Mark g's Avatar
Mark g
I must be missing something, Cause i'm not seeing any such thing on my bike??????????
Old Mar 25, 2008 | 07:05 PM
Mark g's Avatar
Mark g
Duh, yep I was missing something.
I have the heavy breather, it more or less just caps it off and seals it with a o ring.
Old Mar 25, 2008 | 10:07 PM
jag1886's Avatar
jag1886
I have to vote for dumping it on the ground also. If it where that easy to get rid of I'm sure Harley would have done it years ago.
Old Mar 26, 2008 | 06:57 PM
Drodd8's Avatar
Drodd8
ORIGINAL: jag1886
I don't know, look how long it took them to go to fuel injection.
Old Mar 26, 2008 | 08:28 PM
GasCan's Avatar
GasCan
I have external plumbingtapped into the bolts and routes down to the ground. You would not want that condensation that comes from the heads to gather in your oil tank so that idea my friend is a definite NO NO!Route drip lines down to the ground behind the trans.
[sm=forgetit.gif]
