Gas cap question?
Old Mar 29, 2008 | 07:50 PM
LittleBrother's Avatar
LittleBrother
Default Gas cap question?
is this gonna work on my sportster? (XL1200N)
I'm confused as to what type of screw in tank I have
http://cgi.ebay.com/ebaymotors/NEW-B...spagenameZWDVW
-LB
Old Mar 29, 2008 | 08:05 PM
schumacher's Avatar
schumacher
Default RE: Gas cap question?
expensive gas cap........but yeh, should work I think.
Old Mar 29, 2008 | 08:20 PM
DannyZ71's Avatar
DannyZ71
ORIGINAL: schumacher
+1 "Should" work. This would bother me though....................
COMES WITH RUBBER GASKET BUT YOU MAY NEED TO ADD AN O-RING GASKET OR OTHER GASKET TO HAVE IT ALIGN STRAIGHT WHEN IT'S TIGHTENED
You spend $80.00 for a gas cap, you shouldn't have to modify it.
Old Mar 29, 2008 | 08:48 PM
longboard2's Avatar
longboard2
6th Gear
ONE QUESTION WHICH COULD COME UP IS IF YOU NEED A VENTED CAP...
Old Mar 30, 2008 | 01:36 AM
883piglet's Avatar
883piglet
I believe the reason for adding the o ring is so that the bars on the cap can be aligned so that they loook symetrical to the tank
Old Mar 30, 2008 | 07:27 AM
Doug45601's Avatar
Doug45601
that's a standard screw-in thread for Harley tanks... Only difference is the top and threads are solid..(no ratchet free spinnning) when the cap is screwed in tight. that would be the reason for the additional "o" ring as mentioned above.
Secondly, yes it's a vented cap of which you need... helps prevent the vacuum from building in the tank as fuel is being used.
Nice gas cap but expensive!
Old Mar 30, 2008 | 10:16 AM
LittleBrother
Thanks for the replies... I've wanted it for a LONG time, but haven't pulled the trigger... just wondering if it would work and if I should put it on the "To Buy" list.
-LB
Old Mar 30, 2008 | 10:24 AM
883piglet's Avatar
883piglet
I was just looking through the j&p catalog and seen that they carry them also and it is about the same price outright. so I would not get in a bidding war ove that one
Bob
Old Mar 30, 2008 | 10:37 AM
883piglet's Avatar
883piglet
Just looked at J&P online ant that one states that it fits 1982-E96. I am assuming that e96 means early 96. Anyway it is listed for $86.99 They also have this in chrome for $115.99
Cozz
Jan 3, 2017 05:37 PM
Redlegvzv
Oct 7, 2014 04:39 PM
zyban
Feb 18, 2011 01:03 AM
Xenomorph
May 20, 2010 11:51 AM
brohrs
Oct 27, 2005 04:42 PM
