Starting up question
Old Mar 31, 2008 | 09:35 AM
kelton3's Avatar
kelton3
Default Starting up question
First off all I want to thank everyone who has resolved my previous issues with my bike. I love the collaborative effort and the collective expertise, you guys are great (plus you have saved me some money)!
Here's my question on a 1991 xlh 1200: (Brand new battery) This usually happens after I've been riding a bit and pull over and shut it down-- When I try to restart nothing happens (no sound, not even clicking). For the first 2 or 3 tries, I'll flip the kill switch couple of times, turn the key off and on, then after about 2 or 3 presses on the start button, it will start. I'm thinking I'm not holding down the start button long enough? Is it the starter? Or is this normal?
Thanks again...
Old Mar 31, 2008 | 10:27 AM
Thumper26's Avatar
Thumper26
Default RE: Starting up question
The first thing I'd check are all four ends of your battery cables. Make sure they are clean and tight. For some reason, Sportsters have a habit of having these connections being less than solid.
When you are hitting the start or run buttons after the initial failure to start, you are also moving or shaking the bike to a minor degree. This shaking is frequently enough to make sufficient contact for it to start.
There should be no reason, "...thinking I'm not holding down the start button long enough...".
Old Mar 31, 2008 | 10:45 AM
Pacemaker's Avatar
Pacemaker
My brother in-law had the same problem. After I checked all connections ofthe battery and starter, started to wiggle the key and I would get it to startand then it wouldn't. So I replaced the ignition switch and the problem was fixed.
ThrillKilla
Oct 7, 2023 08:02 PM
leachman
May 2, 2015 08:20 AM
tar_snake
Engine Mechanical Topics
24
Apr 2, 2015 08:51 AM
JT-FXDL
Sep 7, 2012 10:53 PM
tidefan60
Aug 7, 2010 03:25 PM
