fork spring spacers
Old Apr 1, 2008 | 08:37 AM
ssls6's Avatar
ssls6
Default fork spring spacers
My wife has a 07 XL1200L. Great bike but the front fork springs have a little too much sag. Can spacers be used to increase fork spring preload?
Old Apr 1, 2008 | 09:08 AM
DPete's Avatar
DPete
Default RE: fork spring spacers
I would think so, the spacers that come with Progressive springs are just schedule 80 PVC pipe cut to length with a washer between the spring and spacer.
Old Apr 1, 2008 | 09:18 AM
Thumper26's Avatar
Thumper26
I would think you can increase pre-load just as DPete says, but if the stockers have too much sag for you, then I really think you'd be better off with a set of standard Progressive Fork Springs. The stock springs are not progressive so by adding pre-load spacers you may not get the desired effect.
Old Apr 1, 2008 | 11:36 AM
cHarley's Avatar
cHarley
I think DPete is right. The stock springs are however longer than the replacement Progressive springs, so I would think a 1-1.5" max. long spacer would be about right along with the washer in-between. It's pretty inexpensive to try it. You could also change to the heavier SE fork oil.
If that doesn't work out, a set of Progressive springs are around $75 bucks. You don't want the SE fork oil here though, just standard 15w fork oil.
Scudda
Jan 10, 2018 05:31 PM
empire_corsa
Jul 14, 2011 05:28 PM
tinman67
Aug 2, 2009 06:31 AM
James23
Apr 10, 2008 06:31 PM
hogbag07
Jan 5, 2008 01:21 PM
