ORIGINAL: egeiselman
Okay, that makes sense. So the gaps should face eachother right?
Keep in mind in the combustion chamber you want the fuel to burn. Sure it is fast but it is a burn not an explosion (detonation).
The problem with dual pulgs is if they create two flame fronts & the two fronts need to work together.
With both plugs facing into the chamber you will get a more controlled burn.
The irons, shovels & earlier engines had/have hemi heads & the plug orientation would affect the burn more noticably as the flame has to travel over the extreme dome of the piston.
I use the standard old cheap Autolights, they last longer than anything else and I do index all my plugs when I install then. I useMoroso indexing washers.
