wiring bars internally...
Old Apr 13, 2008 | 07:44 PM
motordrum's Avatar
motordrum
Default wiring bars internally...
Thinking about getting some awesome Frisco bars from Biltwell. The problem is that they are not dimpled so I would have to drill them out to run them internally. I would make the first hole just inside of the assembly I would think, question is, where should they exit? In the bottom or out the back at the bottom?
Thanks.
Old Apr 13, 2008 | 08:39 PM
6o66er's Avatar
6o66er
Default RE: wiring bars internally...
Right on the bottom....and when you do it, make either 2 separate 1/2" holes or one 1/2"x1" hole. You can use a dremel with a grinding/cutting wheel to make the 1/2"x1" after you punch it in with the drill.
The 2 separate holes look cleaner and if done correctly are more reliable as they don't let anything move around alot. Rubber gromets from autozone or checker are also a good idea because they'll keep the inside edges from cutting into the wires and causing shorts.
Old Apr 13, 2008 | 09:32 PM
motordrum's Avatar
motordrum
So I put the two holes at the bottom between the risers?
Old Apr 13, 2008 | 09:45 PM
6o66er's Avatar
6o66er
Yep. And you're probably gonna need a good hammer drill...use a couple smaller bits as pilots to keep it clean, and take your time or you'll lock the bit up.
Old Apr 13, 2008 | 11:29 PM
motordrum's Avatar
motordrum
Thanks for the advice 6o66er. I will probably use my mill/drill press at work.
Old Apr 14, 2008 | 09:46 AM
jmflh's Avatar
jmflh
http://www.bikernet.com/garage/barwiring.asp
Here's a good site for bar wiring. Believe I got off the HDF.
F86
Jan 10, 2018 02:34 PM
JSager89
General Topics/Tech Tips
Nov 30, 2017 01:23 PM
motordrum
Mar 26, 2010 12:52 PM
DrPlastic
Nov 10, 2007 10:22 PM
XKROME
Sep 12, 2007 02:03 AM
