Pop your A/C off and make SURE you're getting gas, then, check to make sure your coil is working, then, make sure your bank angle sensor isn't on the fritz, then check your ignition module connector is clean and connected correctly, aaaaaaaand DENNNN........listen to everyone else that's about to post after me.
