'key light" stays on... help.
Old Apr 29, 2008 | 12:33 PM
motordrum's Avatar
motordrum
Default 'key light" stays on... help.
Does anyone know why the key light is staying on while running? It just started doing it today. I'm not at home so I can't look in the manual.
Old Apr 29, 2008 | 02:54 PM
HOTLAP's Avatar
HOTLAP
Default RE: 'key light" stays on... help.
Just a guess here but if you have the security system maybe your fob battery is low?
Old Apr 29, 2008 | 03:23 PM
Thumper26's Avatar
Thumper26
I'm guessing here too, but did the bike exceed it's "lean level" and activate the automatic engine shutdown. Even though it runs, it may have tripped that key light.(?)
Try cycling the key in the ignition 5 times rapidly and see if it will go out.
Keep us posted, and good luck!
Old Apr 29, 2008 | 04:21 PM
HOTLAP's Avatar
HOTLAP
Just checked the manual under security status indicator andthe only thing it says about the key light staying on is:
"Service: a key icon that remains illuminated longer than four seconds indicates that service of the module is required"
Old Apr 29, 2008 | 04:47 PM
Thumper26's Avatar
Thumper26
I just got a chance to check my manual, and it says (on page 70 of my manual, Table 17, Security Lamp Status):
STATUS: If security lamp stays ON solid with ignition key ON
MODE: If solid for more than 8 seconds after key is ON, a current trouble code is present.
j09789
Jun 16, 2020 04:48 PM
Gustoking77
Electrical/Lighting/Alarm
Jun 21, 2015 09:29 PM
iclick
Jul 3, 2012 12:00 PM
B-Duff
May 8, 2011 04:58 PM
illini88
Apr 18, 2010 11:25 PM
