Cable metal housing? loose near grips--normal?
Old May 1, 2008 | 05:02 PM
kelton3's Avatar
kelton3
Default Cable metal housing? loose near grips--normal?
Is it normal for the housing, (the metal part attached to the throttle and brake grips) to be loose at the point of the contact with the grips? Mine really wiggle. (That's what she said).
Thanks for all the help..
Old May 1, 2008 | 05:27 PM
6o66er's Avatar
6o66er
Default RE: Cable metal housing? loose near grips--normal?
HUH? Which part are you talking about? The actual brackets and switch housings? If so...no, they shouldn't be.
Old May 1, 2008 | 05:40 PM
kelton3's Avatar
kelton3
It's the metal hollow bent tube where the cable starts from the hand grips.
Old May 1, 2008 | 06:12 PM
northern64's Avatar
northern64
yeah, mine are loose too, i couldnt figure out a way to make em tight so i said "@#$% it" 500 miles later they seem to function just fine.
Old May 1, 2008 | 06:14 PM
kelton3's Avatar
kelton3
I'll be in a Harley store tomorrow and I'll giggle a few "nipples". Proper name of that part.
Old May 1, 2008 | 06:47 PM
HOTLAP's Avatar
HOTLAP
My nippleswiggle too, I think it's normal.
Old May 1, 2008 | 06:54 PM
PigInaBlanket's Avatar
PigInaBlanket
I just tried wiggling my nipples and they did wiggle but I couldn't reach them to try licking them. The neighbor started looking at me funny so I shut the garage door and went in the house. [8D]
Actually I think there is about 1/8 inch of play.
Old May 1, 2008 | 06:56 PM
kelton3's Avatar
kelton3
I didn't mean those nipples! Those are usually loose all the time.
Old May 1, 2008 | 07:03 PM
HOTLAP's Avatar
HOTLAP
If they jiggle when you wiggle, it'll make you giggle
Old May 1, 2008 | 07:11 PM
Demonsmasher's Avatar
Demonsmasher
It's normal. I thought the same thing. Then I "tested" some at the dealership. Tey do the samething. I guess it's for when you turn the handle bars It allows movement of the cables.
