Starting problems
Old May 2, 2008 | 06:51 AM
TigerofH's Avatar
TigerofH
Default Starting problems
So I've having a bit of a problem with my bike. The past couple days I've ridden around. When I get off it and shut it off it takes a lot of cranking to get it to turn back over. I've done everything from prime the carb and opening it to full choke to just starting it with no choke or priming. Anyone got any ideas?
Old May 2, 2008 | 07:00 AM
Mandog's Avatar
Mandog
Default RE: Starting problems
ORIGINAL: TigerofH
Could be Karma for the granda pa bike thing. Also has the bike been sitting all winter? Could be bad gas, dirty carb or a dirty jet. How long you riding before this happens?
Old May 2, 2008 | 07:01 AM
cHarley's Avatar
cHarley
Usually, a warm engine on a warm day should not require any choke or twisting of the throttle. When the engine does catch, do you get a bit of black smoke from the exhaust? If so, that would indicate you might be flooded.
Old May 2, 2008 | 07:49 AM
TigerofH's Avatar
TigerofH
I got the bike in February. Until then it was in a dealership wharehouse. It had the carb re-jetted shortly before I got it. I've also put about 600 miles or so on it sinceit came into my possession. It may be the bad gas thing, because it wasn't doing it until I filled up at a local station down the road a couple days ago. It had never done that in the couple times I filled it up there before though. When its been doing it, I've ridden for at least 15 minutes before shutting it off. I've not noticed any black smoke, but I haven't looked for it.
Bsanchez13
May 25, 2018 08:37 PM
jinx1080
Jun 4, 2012 09:46 PM
snvts82
Apr 27, 2011 03:39 PM
JohnFlorida
Exhaust System Topics
Apr 26, 2011 02:33 PM
Tom19461992
EVO
Apr 8, 2007 04:50 AM
