883L throttle problem
Old May 20, 2008 | 06:57 PM
Tdog1's Avatar
Tdog1
Default 883L throttle problem
I have a new 883L with 300 miles on her.
The throttle grip has some 3/4 of a turn of free play.
How do I tighten this up ?
Old May 20, 2008 | 06:58 PM
anubisss's Avatar
anubisss
Default RE: 883L throttle problem
Adjust the throttle cables that come out right below the grip...
Old May 20, 2008 | 07:02 PM
Tdog1's Avatar
Tdog1
You are not referring to that plastic star nut are you ? Isnt that for long haul ride to let you ease the hand grip
If not, im not seeing anyting on the cable to turn out.
thanks !
Old May 20, 2008 | 07:07 PM
anubisss's Avatar
anubisss
Should look kinda like this except this is a rusty jap bike. Loosen the small lock nut on each cable and turn until the desired amount of free play is attained.
Old May 20, 2008 | 07:10 PM
Tdog1's Avatar
Tdog1
Cool. Going to garage now to try.
Ill report back. thanks again
Old May 20, 2008 | 07:41 PM
Tdog1's Avatar
Tdog1
That worked, but I had to turn out the larger nut to where I almost ran out of thread. I tightened the small nut and i think we are good for now.
I take if I need to do this again that I will need to cut cable ? I removed the throttle cap on handle and see that there is an eye at the end of the cable on a half wheel. If I do need to get shorter what are my next options ?
Thanks for your help bro
Tdog
Old May 20, 2008 | 07:44 PM
Tdog1's Avatar
Tdog1
Also, in order to remove the play, I found that i had to turn large nut counter-clockwise (make it longer). I thought it would be the other way around thinking clockwise would tighten it at grip
Old May 20, 2008 | 08:49 PM
SpursDarkrider's Avatar
SpursDarkrider
get yourself a service manual for your year bike, either the HD one or a clymers or even both wont hurt having. The "fix my hog" DVD for the sportster is great to have also
Old May 20, 2008 | 08:56 PM
HOTLAP's Avatar
HOTLAP
You should not have to be messing with it at all with a new bike with only 300 miles on it, there must be something else wrong especially if your right at the end of your adjustment already, get it into the dealer. (that is if I understand your post that this is a new bike).
Old May 20, 2008 | 10:10 PM
Tdog1's Avatar
Tdog1
Word.
I'm going back to Dillon Harley Omaha next week. They are supposedly the #11 Harley dealership in the country.
damager1
Oct 30, 2015 07:05 PM
c-note
Jun 17, 2014 07:59 PM
GlennB.
Aug 18, 2011 04:15 AM
skdvr
Aug 3, 2010 05:35 PM
crepe
General Topics/Tech Tips
Apr 27, 2009 02:58 AM
