Front Brake Noise
Old May 30, 2008 | 02:47 PM
smtrickett's Avatar
smtrickett
Default Front Brake Noise
My front brakes appear to be in contact with the rotor, without compression of the lever. I hear them press fluid to the caliper, and quite a bit of friction noise when stopping. Is this normal?
Old May 30, 2008 | 02:55 PM
sweetroll's Avatar
sweetroll
Default RE: Front Brake Noise
It's normal for the pads to be in slight contact w/ the rotor w/o having the brake on, and you'll hear them rubbing if you push the bike w/o the engine on. Some scraping noise when you're stopping is also normal, especially if they're new. If there's a lot of squealing then it might be time to clean them.
As for the fluid noise, it might be time to bleed the calipers - there might be some air in there that's moving around with the fluid, which is definitly not good (major loss in braking force).
How new is the bike?
Old May 30, 2008 | 04:56 PM
smtrickett's Avatar
smtrickett
I hear the rubbing even in motion, of course not when hitting it hard and accelerating. Its not a scraping sound, so it wouldnt concern me in a car. The brakes are new, just have them all replaced. So, maybe a little bleed is a good idea. Thanks, I will try that.
lonwof
Sep 4, 2017 05:34 PM
Surfit
General Topics/Tech Tips
May 2, 2014 10:20 AM
Edywazoo
Wheels/Tires
Jul 19, 2013 07:25 PM
Liv42Day
Oct 17, 2010 07:19 AM
JerseyDevil
Oct 3, 2008 09:16 PM
