Under Pressure
Old Mar 1, 2006 | 07:20 PM
slackr's Avatar
slackr
Default Under Pressure
just wonder guys what do you run your tire press at do u go by what it says on the tire..do u run the same in the front and back ..just wondering if anyone runs differnt .
Old Mar 1, 2006 | 08:54 PM
alexcue's Avatar
alexcue
Default RE: Under Pressure
Personally run mine at 30 front and 38 rear. If i remember correctly, I'm about 2 pounds higher in the rear than recommended. But I'm a heavyweight. It actually helped improve the ride quite a bit. Ride will be much better once i buy/install some progressive 418's tho.
Old Mar 2, 2006 | 11:24 AM
Thumper26's Avatar
Thumper26
I run the reco'd 30 lbs. front and 36 lbs. rear.
Thumper26
Old Mar 2, 2006 | 09:20 PM
gumby62's Avatar
gumby62
Exactly what the tire manufacturer calls for most of the time, 2 lbs. less when the temps are expected to be over 90 degrees for any length of time.
Old Mar 3, 2006 | 12:20 AM
ChopperHammer666's Avatar
ChopperHammer666
Remember to check the tire pressure when the tire is cold. I always run the recommended in the front and +2 lbs in the rear also. (Im a big boy!) On my first set of tires (I ran the HD rear pressure) the rear wore square even though I never did burn-outs and never allot of straight riding.
Old Mar 3, 2006 | 12:57 AM
wildbill13's Avatar
wildbill13
6th Gear
personally, i run mine at the recomended pressure in the front and -2 or so in back. you get a little more rubber on the ground which helps grip and handeling in hard cornering.
Old Mar 3, 2006 | 01:00 AM
AZFlyingDiver's Avatar
AZFlyingDiver
ORIGINAL: Thumper26
Thumper26
Ditto.
oldtech
Oct 22, 2012 07:58 AM
utz
Sep 10, 2009 08:21 AM
manowar
Jul 29, 2006 12:37 AM
Rhode Warrior
May 10, 2006 09:55 PM
KCEddy
Oct 5, 2005 01:34 PM
