SPEEDO
Old Jun 21, 2008 | 10:54 AM
kensporty 01's Avatar
kensporty 01
6th Gear
Default SPEEDO
I replaced speedo sensor and still have no speedo, I have blacklight and turn sig. but they do not turn off&nbsp\\;I have to turn them off. any help or info on this I would be greatful, I HAVE A 2001 1200C
Old Jun 21, 2008 | 11:31 AM
capttawes's Avatar
capttawes
Default RE: SPEEDO
Not familiar with wiring schem. on an 01 but you might pull the plug under the tank for the speedo&nbsp\\;and look for any corrosion o the connector pins/sockets&nbsp\\;causing poor contact or a bad ground connection.
Old Jun 21, 2008 | 11:45 AM
Tommo's Avatar
Tommo
Default RE: SPEEDO
After having looked at a wiring diagram for your bike...the speed output in the speedo is wired to the vss in the turn signal module...searched vss and found this post...sounds similar...
&nbsp\\;\\\\\\;
https://www.hdforums.com/m_1323634/tm.htm
&nbsp\\;
Ahh!.....after re-reading your post.....guess you've already done this....sorry.[&:]
Old Jun 21, 2008 | 01:04 PM
Fordster's Avatar
Fordster
Default RE: SPEEDO
Hi kensporty i hope you dont think im crazy for this suggestion i dont know what kind of spark plug wires you have but my dad had the same problem with his sporty.He changed the speed sensor and had the same problem he had those steel braided plug wires on his the dealer told him that those plug wires create interference with the speed sensor.So he put the stock spark plug wires back on it and now everything works perfect that was a new one on me but sure enough that was the problem.I dont know if this applies to your bike but i hope maybe it helps you out.
Old Jun 21, 2008 | 05:30 PM
kensporty 01
6th Gear
Default RE: SPEEDO
ok I did all that and went thru the diagnostic mode and this came up
do2 see
do5 see
and at the end it reads ppu so I am really lost now???
Old Jun 21, 2008 | 05:43 PM
Tommo's Avatar
Tommo
Default RE: SPEEDO
Have you had a look at the thread&nbsp\\; above the one thats always there by Schui?
https://www.hdforums.com/m_3143107/tm.htm
Old Jun 21, 2008 | 06:20 PM
kensporty 01
6th Gear
Default RE: SPEEDO
No I haven't really can't seem to find what u are talking about I am just fed up trying to get this working!!!!!!!!
Old Jun 21, 2008 | 06:35 PM
Tommo's Avatar
Tommo
Default RE: SPEEDO
I've had a quick look,and the codes you mention...do2=speed sensor output shorted high or open......do5=speed sensor return high......haven't found ppu yet......make of It what you will......good luck.
&nbsp\\;
I see you've had this problem quite a while......hang In there mate.
powerengineer
May 6, 2017 11:33 PM
camwat
Mar 2, 2017 07:07 AM
Joel282
Aug 5, 2016 10:09 AM
Ticket
Electrical/Lighting/Alarm
Mar 3, 2015 01:22 AM
Horser72
Dec 17, 2013 11:57 AM
