Another starting problem....
Old Jun 22, 2008 | 03:15 PM
dieselboy973's Avatar
dieselboy973
1st Gear
Default Another starting problem....
I have an 08 nightster with 1,600 miles and it has been running fine until this morning. When I went to start it, turned on the run switch, fuel pump kicked on, then i hit the ignition and it clicked once and the entire bike went dark. I have check the fuses and they all seem fine. I pulled out both relays and when i put them back in I was able to get a small flicker out of the lights and the speedo, but still won't start up. Has this happened to anyone else? Any advice would be helpful, i an trying to avoid bringing it back to the dealer. Thanks
Old Jun 22, 2008 | 03:25 PM
HOTLAP's Avatar
HOTLAP
Default RE: Another starting problem....
Check your connections at the battery and the frame ground and at the starter. Do you have a test light to see if there is power in the battery, maybe left the key in the ACC position and killed the battery?
Old Jun 22, 2008 | 03:37 PM
dieselboy973
1st Gear
The key was out of the bike last night. I checked the connection and they all seem to be solid. I was able to get the fuel pump to kick on again, but once I ht the ignition switch again the bike went completely off again, thats why I'm thinking maybe a relay problem. Is there any way to check the relays to see if they are still good? They look fine, no corrosion.
Old Jun 22, 2008 | 04:00 PM
hogsport's Avatar
hogsport
Doesn't your ignition switch have to be on for the fuel pump to come on?&nbsp\\; - are you talking about the starter switch?
Old Jun 22, 2008 | 05:14 PM
HOTLAP's Avatar
HOTLAP
ORIGINAL: dieselboy973
&nbsp\\;
My key comes out when it is in the ACC position so it is possible to run down the battery even though the key is out, I dont think there is a relay that would shut down the whole bike, only the maxi fuse would do that but if it was blown you would have no power at all, it does sound to me like the battery is dead and only has a tiny amount of power to run the fuel pump for a few seconds, you need to get a multi meter or at least a test light on the battery to see if it is charged or not.
Old Jun 22, 2008 | 05:20 PM
jlandis874's Avatar
jlandis874
Same thing happened to me a few weeks ago. Dealer took it in, told me they charged it up and found nothing wrong with it. Now its back in the shop for the 2nd time, (bike is&nbsp\\;4 months old), been three days and they still can't tell me whats wrong with it. F&amp\\;S Harley Davidson in Dayton, OH has lost all future business from me after this.
Old Jun 22, 2008 | 10:15 PM
dieselboy973
1st Gear
I'm fixed. Went back over the bike and put a wrench to both battery terminals and the bike started right up. So I guess it was just a loose terminal after all. Thank you for all your help.
Vintage1951
Oct 21, 2017 04:16 PM
SugsPa
Jun 2, 2017 08:21 AM
ms3300
Feb 5, 2014 04:59 PM
Lex_Talionis
Nov 22, 2011 09:10 PM
1150A
Feb 6, 2011 03:40 PM
